The 150Mbps micro wireless N USB adapter (model TEW-648UBM) quickly connects a laptop or desktop computer to a high speed wireless N network.
Enjoy proven wireless N speed and reliability, in a micro design that extends less than three eighths of an inch (9mm) from the edge of a computer. Connecting to a network is made easy with the external one-touch Wi-Fi Protected Setup (WPS) button. Advanced wireless encryption protects your valuable data. Wi-Fi Multimedia (WMM) Quality of Service (QoS) prioritizes important video, audio, and gaming traffic. Seamlessly stream video, download files, and play games with this ultra compact wireless n adapter.
USB 2.0 connector
Ultra compact form factor
Wi-Fi compliant with IEEE 802.11n standard
One-touch wireless connection with external Wi-Fi Protected Setup (WPS) button
Backwards compatible with IEEE 802.11g and IEEE 802.11b devices
Maximum reliability, throughput, and connectivity with automatic data rate switching
Supports 64/128-bit WEP, WPA/WPA2-RADIUS, and WPA-PSK/WPA2-PSK
Wi-Fi Multimedia (WMM) Quality of Service (QoS) data prioritization
Easy user setup and intuitive diagnostic utility
Coverage of up to 30 meters indoor (98 feet) and 50 meters outdoor (164 feet) *
3-year limited warranty
- TRENDnet TEW-648UBM - network adapter - USB 2.0 - TAA Compliant
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- USB 2.0
- 2 cm x 0.7 cm x 1.5 cm
- 1 g
- Data Link Protocol
- 802.11b/g/n
- Data Transfer Rate
- 150 Mbps
- Frequency Band
- 2.4 GHz
- IEEE 802.11b, IEEE 802.11g, Wi-Fi CERTIFIED, USB 2.0, IEEE 802.11n
- System Requirements
- Microsoft Windows 2000, Microsoft Windows XP, Microsoft Windows XP 64-bit Edition, Microsoft Windows 7, Microsoft Windows Vista, Microsoft Windows 7 64-bit Edition, Microsoft Windows Vista (64-bit versions)
- Microsoft Certification
- Compatible with Windows 7
- TAA Compliant
- 3-year warranty
- Network adapter
- Form Factor
- External
- USB 2.0
- Connectivity Technology
- Wireless
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Spread Spectrum Method
- OFDM, DSSS
- 150 Mbps
- Line Coding Format
- OFDM
- Frequency Band
- 2.4 GHz
- Max Range Indoors
- 30 m
- Max Range Open Space
- 100 m
- Status Indicators
- Link/activity
- Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Wi-Fi Protected Setup (WPS)
Aerial
- Antenna
- Internal
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- ETSI, FCC
- TAA Compliant
- Software Included
- Drivers & Utilities
- OS Required
- 2 cm
- 0.7 cm
- 1.5 cm
- 1 g
- Limited warranty - 3 years
- 0 °C
- 40 °C
- 0 - 95% (non-condensing)
