TRENDnet 12-Port Gigabit PoE+ Smart Surveillance Switch
Quicklinx: FQ95WS00 Mfr#: TPE-3012LS
TRENDnet's Gigabit PoE+ Smart Surveillance Switch series is designed to simplify the installation and management of surveillance networks, especially for integrators and installers. These ONVIF switches are optimized for the surveillance industry; surveillance mode provides a graphical dashboard interface with detailed information about the switch and each connected PoE device. Connect ONVIF compliant IP cameras and NVRs for more advanced capabilities such as changing device IP settings, and to view individual IP camera video within the switch GUI. The Smart Surveillance Switches are also PoE self-healing switches featuring PoE device auto-recovery and power scheduling.
Installers and integrators can save on equipment costs and reduce installation time with TRENDnet's Gigabit PoE+ Smart Surveillance Switches by delivering up to 30W per port of PoE power and data over existing Ethernet cables. Available PoE port controls include enabling and disabling PoE, PD alive check, and power scheduling. PD alive check is an automated PoE self-healing switch feature that attempts to recover an unresponsive PoE device connected to the switch. If a PoE device such as a PoE camera becomes unresponsive to pings, the ONVIF compliant switch will auto-reboot the PoE port in attempt to recover the device.
These PoE+ ONVIF switches feature a 4-digit LED display showing total PoE power, available power, and power-per-port. They also support long distance PoE+ networking up to 656 ft./200m away at speeds up to 10mbps. TRENDnet's Gigabit PoE+ Smart Surveillance Switches also feature SFP slots to support long-distance fiber networking applications.
Advanced managed switch features include LACP to group ports together to increase bandwidth between switches, VLANs for segmenting and isolating virtual LAN groups, QoS for traffic prioritization, port bandwidth controls, and SNMP monitoring, making this ONVIF switch a powerful SMB network solution. Improve voice performance by isolating and prioritizing VoIP traffic from normal data traffic with the easy-to-use voice VLAN feature.
TRENDnet TPE 3012LS - switch - 12 ports - smart - rack-mountable - TAA Compliant
Switch - 12 ports - smart
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
8 x 10/100/1000 (PoE+) + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
110 W
Performance
Switching capacity: 24 Gbps , Switching fabric bandwidth: 24 Gbps , Forwarding performance (64-byte packet size): 17.8 Mpps
VLAN groups: 256
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH-2, CLI
VLAN support, IGMP snooping, Syslog support, port mirroring, Broadcast Storm Control, IPv6 support, half duplex mode, full duplex mode, Multicast Storm Control, Unicast Storm Control, STP support, RSTP support, MSTP support, QoS, Cable Diagnostics Function, UDLD, IPv4 support, fanless, LACP support, LLDP support, Port Security, 512KB packet buffer, MVR, tagged VLAN, ONVIF support, per port bandwidth control, DSCP support, IP source guard, Head of Line Blocking Prevention, IGMP querier, protected ports, DoS protection, loopback detection, IGMP immediate leave, Unknown Storm Control
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3az
33 cm x 23 cm x 4.445 cm
2.26 kg
TAA Compliant
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
110 W
Performance
VLAN groups: 256
8K entries
Jumbo Frame Support
10KB
Built-in Devices
LED display
8 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x 1000Base-T RJ-45 , 2 x Gigabit LAN SFP
Internal power supply
10 Watt
Rack Mounting Kit
Included
FCC, ETL
TAA Compliant
33 cm
23 cm
4.445 cm
2.26 kg
Limited warranty - lifetime
0 - 90% (non-condensing)
