TRENDnet 12-Port Cat. 6 Unshielded Patch Panel (10" wide)
Quicklinx: 9YPBWS00 Mfr#: TC-P12C6
The model TC-P12C6 provides a 250MHz connection to 12 x Gigabit RJ-45 Ethernet ports. This 10-inch wide patch panel is well suited for home and SMB applications. Control cable clutter with included removable cable pass-through holders and cable ties. A writing surface above each port allows users to label respective connections.
TRENDnet patch panel
Patch panel - CAT 6 - RJ-45 X 12
Port Qty
12 ports
Wiring Scheme
T568B
UL
Patch panel - CAT 6
Cabling & Wiring
Port Qty
12 ports
Termination Type
110 type termination
Wiring Scheme
T568B
Connector Provided
12 x RJ-45 female
UL
-40 °C
80 °C
