TRENDnet 12-Port Cat. 5e Unshielded Patch Panel (10" wide)
Quicklinx: 9YP8WS00 Mfr#: TC-P12C5E
TC-P12C5E unshielded patch panel provides a 100MHz connection to 8 x Gigabit RJ-45 Ethernet ports. This 10-inch wide patch panel is well suited for home and SMB applications. Control cable clutter with included removable cable pass-through holders and cable ties. A writing surface above each port allows users to label respective connections.
TRENDnet patch panel
Patch panel - CAT 5e
4.4 cm x 25.4 cm x 3 cm
230 g
Port Qty
12 ports
FCC
4.4 cm
25.4 cm
3 cm
230 g
Cabling & Wiring
Port Qty
12 ports
Termination Type
110 type termination
Connector Provided
12 x RJ-45 female
FCC
-10 °C
60 °C
