TRENDnet 100Base-TX to 100Base-FX Multi Mode ST Fiber Converter (2KM)
Quicklinx: 9YLPWS00 Mfr#: TFC-110MST
TRENDnet's TFC-110 series Fiber Media Converter transforms 10/100BaseTX UTP/STP media to 100BaseFX media and vice versa. The 10/100BaseTX port auto-senses 10 or 100Mbps connection speed, auto-negotiates half-/full-duplex mode, and auto-selects MDI-X / MDI-II media type. The fiber connection can be multi-mode SC, MT-RJ, or single-mode SC Connector and it has a slide-switch for selecting half- or full-duplex mode. This converter will give your Switch/Hub the ability to interface with fiber connection over a distance up to 75 km. With the optional 16-slot EIA-19" rack-mount chassis, the TFC series converters are the perfect solutions for various fiber media conversions for your network.
TRENDnet TFC-110 MST - fibre media converter - 10Mb LAN, 100Mb LAN - TAA Compliant
Fibre media converter - ST multi-mode / RJ-45
External
Cabling Type
10Base-T, 100Base-FX, 100Base-TX
Data Transfer Rate
100 Mbps
10Mb LAN, 100Mb LAN
Max Transfer Distance
2 km
12 cm x 8.8 cm x 2.5 cm
0.4 kg
TAA Compliant
External
Wired
Cabling Type
10Mb LAN, 100Mb LAN
Data Transfer Rate
100 Mbps
2 km
Status Indicators
Port transmission speed, port duplex mode, power, link/activity
Full duplex capability, auto-sensing per device, MDI/MDI-X switch, auto-negotiation
IEEE 802.3, IEEE 802.3u
1 x Ethernet 100Base-FX - ST multi-mode female x 2 , 1 x Ethernet 10Base-T/100Base-TX - RJ-45 female
Rack Mounting Kit
Optional
VCCI
TAA Compliant
External power adapter
Power Provided
7.2 watt
12 cm
8.8 cm
2.5 cm
0.4 kg
Limited warranty - lifetime
10 - 90%
