TRENDnet 10-Port Gigabit Web Smart  PoE+ Switch
Quicklinx: FQ8JWS00 Mfr#: TPE-082WS
TRENDnet's 10 Port Gigabit Web Smart PoE+ Switch, model TPE-082WS, delivers advanced management features with a 20Gbps switching capacity. This fanless rack mountable IPv6 ready switch comes with an intuitive web-based interface. Advanced traffic management controls, troubleshooting, and SNMP monitoring support make this a powerful solution for SMB networks. The TPE-082WS provides eight gigabit PoE+ ports with a total power budget of 75 W, and two dedicated SFP slots for fiber applications. The PoE+ standard supplies up to 30 W of power per port for devices such as high power wireless access points, PTZ (Pan Tilt Zoom) Internet cameras, and VoIP telephony systems.
TRENDnet TPE 082WS - switch - 10 ports - rack-mountable - TAA Compliant
Switch - 10 ports
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
10 x 10/100/1000 (PoE+) + 2 x shared Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
75 W
Performance
Forwarding performance (64-byte packet size): 14.9 Mpps , Switching fabric bandwidth: 20 Gbps
IPv6 routes (static): 256 , VLAN IDs: 4094 , Multicast entries (IPv4): 256 , Maximum TCP/UDP sessions: 65535 , MAC address entries: 8000
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Remote Management Protocol
SNMP 1, RMON 1, SNMP 3, SNMP 2c, HTTP, HTTPS
IGMP snooping, port mirroring, Weighted Round Robin (WRR) queuing, IPv6 support, Virtual Cable Test (VCT) technology, DHCP snooping, Quality of Service (QoS), MLD snooping, fanless, LACP support, LLDP support, Dynamic VLAN Support (GVRP), Class of Service (CoS), Strict Priority (SP), Loopback, Denial of Service (DoS), Duplicated Address Detection, per port bandwidth control, DiffServ Code Point (DSCP) support, power-saving mode, Head of Line Blocking Prevention, TCP/UDP port setting, Static Link Aggregation, Voice VLAN, VLAN management, Private VLAN
IEEE 802.3, IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.1s, IEEE 802.1ad, IEEE 802.3at, IEEE 802.3az
28 cm x 12.58 cm x 4.4 cm
920 g
TAA Compliant
Switch - 10 ports
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
PoE+
PoE Budget
75 W
Performance
8K entries
Jumbo Frame Support
10KB
Encryption Algorithm
TLS, SSL 3.0, SSL 2.0
Authentication Method
RADIUS, TACACS+
Status Indicators
Power, PoE, link/activity
8 x 1000Base-T RJ-45 PoE+ - 30 W , 2 x SFP
Internal power supply
82 Watt
Rack Mounting Kit
Included
MTBF
862,966 hours
FCC, IPv6 Ready
TAA Compliant
28 cm
12.58 cm
4.4 cm
920 g
Limited warranty - lifetime
-5 °C
50 °C
95% (non-condensing)
