TRENDnet's 10-Port 2.5G Web Smart PoE+ Switch with eight 2.5GBASE-T PoE+ ports and two 10G SFP+ slots, model TPE-30102WS, delivers advanced management features with an 80Gbps switching capacity. The TPE-30102WS is equipped with 2.5GBASE-T PoE+ ports that provide higher gigabit speeds capable of up to 2.5Gbps over existing Cat5e or better cabling. This switch provides eight PoE+ connections with a total power budget of 240W, and supplies up to 30W of power per port for devices such as wireless access points, PTZ IP cameras, and VoIP telephony systems. This rack mountable IPv6 ready switch comes with an intuitive web-based interface. Advanced traffic management controls include IP routing, VLAN, QoS, access controls, link aggregation, troubleshooting, and SNMP monitoring, making this a powerful solution for SMB networks.
Web Smart Management
Provides an easy to use web-based GUI management interface for advanced traffic management controls, IP routing, VLAN, QoS, access controls, link aggregation, troubleshooting, SNMP monitoring, per port MAC restriction, and dynamic ARP inspection. -
2.5GBASE-T Full Power PoE+ Ports
Equipped with eight 2.5GBASE-T RJ-45 ports that provide higher gigabit speeds capable of up to 2.5Gbps over existing Cat5e or better cabling. Supplies up to 30W of PoE+ power per port with a total power budget of 240W. -
10G SFP+ Slots
Offers two 10G SFP+ slots for high-speed network connections providing a costeffective solution in adding 10G link capability to an SMB network.
- TRENDnet TPE 30102WS - switch - 10 ports - Managed - rack-mountable
- Switch - 10 ports - Managed
- Enclosure Type
- Rack-mountable 1U
- Subtype
- 2.5 Gigabit Ethernet
- Ports
- 8 x 100/1000/2.5G (PoE+) + 2 x 10 Gigabit SFP+
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 240 W
- Performance
- Switching capacity: 80 Gbps , Forwarding rate: 59.5 Mpps
- Capacity
- Multicast groups: 1000 , VLAN groups: 32 , Routing table entries: 32 , ARP entries: 1024 , IP router interfaces: 8 , IPv4 routes (static): 32 , IPv6 routes (static): 32
- MAC Address Table Size
- 32K entries
- Jumbo Frame Support
- 9KB
- Routing Protocol
- IGMPv2, IGMP, IGMPv3
- Remote Management Protocol
- SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH-2, CLI
- DHCP support, port mirroring, MAC address filtering, half duplex mode, full duplex mode, DHCP snooping, ACL support, RADIUS support, DHCP server, MLD snooping, PoE+, Cable Diagnostics Function, DWRR, hot swappable dual fans, LLDP support, over-current protection, short circuit protection, GVRP, NDP, static routing, SP, Duplicated Address Detection, per port bandwidth control, DSCP support, Storm Control, MIB II, MAC address authentication, Voice VLAN, LLDP-MED, Private VLAN, Inter-VLAN Routing, DoS protection, HOL Blocking Prevention, loopback detection, VLAN Tagging
- IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3bz
- Power
- AC 120/230 V
- 33 cm x 23 cm x 4.445 cm
- 2.71 kg
- 3-year warranty
- Enclosure Type
- Rack-mountable 1U
- Subtype
- Ports
- PoE+
- PoE Budget
- 240 W
- Performance
- Capacity
- 32K entries
- 9KB
- Routing Protocol
- Encryption Algorithm
- SSL 3.0, SSL 2.0, TLS 1.2
- Authentication Method
- RADIUS, TACACS+, MACAuth
- 8 x 1/2.5G (PoE+) RJ-45 30 W , 2 x 10Gbit LAN SFP+ , 1 x console RJ-45
- Voltage Required
- AC 120/230 V
- 27.36 Watt
- MTBF
- 433,898 hours
- UL, FCC
- 33 cm
- 23 cm
- 4.445 cm
- 2.71 kg
- Limited warranty - 3 years
- 0 °C
- 50 °C
- 80% (non-condensing)
