TRENDnet 10-Port 2.5GBASE-T Web Smart+ PoE+ Switch
Quicklinx: FQ87WS00 Mfr#: TPE-30102WS
TRENDnet's 10-Port 2.5G Web Smart PoE+ Switch with eight 2.5GBASE-T PoE+ ports and two 10G SFP+ slots, model TPE-30102WS, delivers advanced management features with an 80Gbps switching capacity. The TPE-30102WS is equipped with 2.5GBASE-T PoE+ ports that provide higher gigabit speeds capable of up to 2.5Gbps over existing Cat5e or better cabling. This switch provides eight PoE+ connections with a total power budget of 240W, and supplies up to 30W of power per port for devices such as wireless access points, PTZ IP cameras, and VoIP telephony systems. This rack mountable IPv6 ready switch comes with an intuitive web-based interface. Advanced traffic management controls include IP routing, VLAN, QoS, access controls, link aggregation, troubleshooting, and SNMP monitoring, making this a powerful solution for SMB networks.
  • Web Smart Management
    Provides an easy to use web-based GUI management interface for advanced traffic management controls, IP routing, VLAN, QoS, access controls, link aggregation, troubleshooting, SNMP monitoring, per port MAC restriction, and dynamic ARP inspection.
  • 2.5GBASE-T Full Power PoE+ Ports
    Equipped with eight 2.5GBASE-T RJ-45 ports that provide higher gigabit speeds capable of up to 2.5Gbps over existing Cat5e or better cabling. Supplies up to 30W of PoE+ power per port with a total power budget of 240W.
  • 10G SFP+ Slots
    Offers two 10G SFP+ slots for high-speed network connections providing a costeffective solution in adding 10G link capability to an SMB network.
TRENDnet TPE 30102WS - switch - 10 ports - Managed - rack-mountable
Switch - 10 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
2.5 Gigabit Ethernet
Ports
8 x 100/1000/2.5G (PoE+) + 2 x 10 Gigabit SFP+
Power Over Ethernet (PoE)
PoE+
PoE Budget
240 W
Performance
Switching capacity: 80 Gbps , Forwarding rate: 59.5 Mpps
Multicast groups: 1000 , VLAN groups: 32 , Routing table entries: 32 , ARP entries: 1024 , IP router interfaces: 8 , IPv4 routes (static): 32 , IPv6 routes (static): 32
MAC Address Table Size
32K entries
Jumbo Frame Support
9KB
Routing Protocol
IGMPv2, IGMP, IGMPv3
Remote Management Protocol
SNMP 1, RMON 1, RMON 2, RMON 3, RMON 9, Telnet, SNMP 3, SNMP 2c, HTTP, HTTPS, SSH-2, CLI
DHCP support, port mirroring, MAC address filtering, half duplex mode, full duplex mode, DHCP snooping, ACL support, RADIUS support, DHCP server, MLD snooping, PoE+, Cable Diagnostics Function, DWRR, hot swappable dual fans, LLDP support, over-current protection, short circuit protection, GVRP, NDP, static routing, SP, Duplicated Address Detection, per port bandwidth control, DSCP support, Storm Control, MIB II, MAC address authentication, Voice VLAN, LLDP-MED, Private VLAN, Inter-VLAN Routing, DoS protection, HOL Blocking Prevention, loopback detection, VLAN Tagging
IEEE 802.3u, IEEE 802.3z, IEEE 802.1D, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3af, IEEE 802.3x, IEEE 802.3ad (LACP), IEEE 802.1w, IEEE 802.1x, IEEE 802.3ae, IEEE 802.1s, IEEE 802.1ab (LLDP), IEEE 802.3at, IEEE 802.3bz
AC 120/230 V
33 cm x 23 cm x 4.445 cm
2.71 kg
3-year warranty
Enclosure Type
Rack-mountable 1U
Subtype
Ports
PoE+
PoE Budget
240 W
Performance
32K entries
Jumbo Frame Support
9KB
Routing Protocol
Encryption Algorithm
SSL 3.0, SSL 2.0, TLS 1.2
Authentication Method
RADIUS, TACACS+, MACAuth
8 x 1/2.5G (PoE+) RJ-45 30 W , 2 x 10Gbit LAN SFP+ , 1 x console RJ-45
AC 120/230 V
27.36 Watt
MTBF
433,898 hours
UL, FCC
33 cm
23 cm
4.445 cm
2.71 kg
Limited warranty - 3 years
50 °C
80% (non-condensing)
