TRENDnet's 1-Port Multi-Function USB Print Server, model TE100-MFP1, transforms most stand-alone multi-function and standard USB printers into a shared network resource. Install your multifunction printer in the most ergonomic location and then connect the compact TE100-MFP1 to a wired network.
An intuitive utility provides a seamless user experience. Scan, fax, and print functionality from any networked workstation. This compact device fits into the smallest spaces.
- TRENDnet TE100-MFP1 - print server - USB - 10/100 Ethernet
- Print server
- Form Factor
- External
- Interface (Bus) Type
- USB
- Ports
- 10/100 Ethernet
- 5.8 cm x 7.5 cm x 2.4 cm
- 60 g
- Data Link Protocol
- 10Mb LAN, 100Mb LAN
- Capacity
- Bridged devices per station: 127
- TCP/IP, LPR/LPD, DHCP
- IEEE 802.3, IEEE 802.3u, USB 1.1, USB 2.0, UPnP
- Power
- AC 120/230 V (50/60 Hz)
- System Requirements
- Apple MacOS X 10.4, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Apple MacOS X Lion 10.7
- 3-year warranty
- Print server
- Form Factor
- External
- USB
- Ports
- 10/100 Ethernet
- Connectivity Technology
- Wired
- Ethernet, Fast Ethernet
- Capacity
- Status Indicators
- Power, link/activity, USB
- Auto-uplink (auto MDI/MDI-X), reset button, on/off switches, NetUSB support
- 1 x 100Base-TX - RJ-45
- Connections
- 1 x USB 2.0 - 4 pin USB Type A
- Cables Included
- 1 x network cable (external) - 1.5 m
- FCC, RoHS
- Power Device
- Power adapter - external
- Voltage Required
- 1.9 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 5.8 cm
- 7.5 cm
- 2.4 cm
- 60 g
- Limited warranty - 3 years
- 5 °C
- 40 °C
- 0 - 90% (non-condensing)
