Day or night, indoors or outdoors, Transcend's DrivePro Body 10 is the best companion for police officers, security guards and other professionals. The camera's wide 160° viewing angle, ƒ/2.8 aperture lens and Full HD 1080P recordings ensure all the important details of actions are clearly recorded. The infrared LEDs will be automatically turned on in low light conditions, allowing recording and snapshots taking at night. The DrivePro Body 10 also features a built-in battery and excellent water and shock resistance, ideal for indoor and outdoor use.
Collect evidence day and night
With a large ƒ/2.8 aperture, a wide 160° viewing angle and a high-quality camera lens, the DrivePro Body 10 can automatically adjust to different lighting conditions to capture all details of actions during either daytime or nighttime in clear and smooth 1080P (30 fps) recordings. In addition, as infrared LEDs turn on automatically on in low light, recording at night is now easier than ever before. -
Firmly attached with 360° rotatable clip
The DrivePro Body 10 features a 360° rotatable clip that allows you to attach it to clothing or straps, making it easier to record anytime, anywhere. -
Built-in battery for frontline recording
With a built-in 1530 mAh Li-Polymer battery, the DrivePro Body 10 can record long hours of footage on a full charge, mitigating the need for a power adapter for police officers on duty. -
Handy snapshot button
The handy snapshot feature allows you to take photos while recording video. During an incident, press the snapshot button to capture photographic evidence on the spot. -
Optimum outdoor protection
The rugged DrivePro Body 10 provides excellent protection for outdoor recording. The IPX4 water resistant feature offers protection against splashing water from any direction. The DrivePro Body 10 also offers excellent shock resistance, meeting U. S. military drop-test standards.
- Transcend DrivePro Body 10 - camcorder - storage: flash card
- Product Type
- Camcorder - 1080p
- Media Type
- Flash card
- Memory Card Slot
- microSD card
- Max Video Resolution
- 1920 x 1080
- Lens System
- Wide-angle lens f/2.8
- Focus Adjustment
- Focus free
- Supported Battery
- Li-Polymer rechargeable battery - 1530 mAh (included)
- Interface
- USB 2.0
- 5.22 cm x 1.96 cm x 8.84 cm
- 108 g
- 2-year warranty
- Product Type
- Camcorder - 1080p
- Camcorder Type
- Wearable
- Camcorder Media Type
- Flash card
- Frame Rate (Max Resolution)
- 30 fps
- Digital Video Format
- H.264, MOV
- 1920 x 1080
- Interface
- USB 2.0
Lens System
- Focus Adjustment
- Focus free
- Max View Angle
- 160 degree(s)
Additional Features
- Additional Features
- Takes photos while film recording, built-in IR illuminator
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0
- Included Accessories
- Swivel clip, micro-USB cable
- Protection
- Splashproof, shockproof
- Battery Type
- Lithium polymer - integrated
- Details
- Battery Life Details
- Video recording - 3.5 hours
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card
- 32 GB microSDHC
- Memory Card Included
- Video Capture
- H.264 - 1920 x 1080 p - 30 fps
- Limited warranty - 2 years
- 5.22 cm
- 1.96 cm
- 8.84 cm
- 108 g
- -20 °C
- 65 °C
