Suction mount TS-DPM1 is compatible with Transcend DrivePro 200 Car Video Recorders. Easy to install, locking T tip (easy to adjust desired angle) and 360 degree swivel.
Product Features
- Locking T tip, easy to adjust desired angle
- Suction pad
- 360 degree swivel
- Easy to install
- Suitable for Transcend Car Video Recorder Series
Sturdy support system
The Transcend TS-DPM1 features a robust support system that firmly holds dashboard cameras in place, ensuring uninterrupted recording while driving. -
Simple installation
With its suction mount design, this tripod allows for a straightforward setup on the windshield, making it user-friendly.
- Transcend TS-DPM1 support system - suction mount
- Product Type
- Support system - suction mount
- Placing / Mounting
- Wind shield
- Designed For
- DrivePro 200, 620
- Product Type
- Support system
Tripod
- Wind shield
- Supported Devices
- Dashboard camera
- Support Type
- Suction mount
- Designed For
- Transcend DrivePro 200, 620
