Transcend DrivePro 520, 2.4" LCD, with Adhesive Mount 32Gb
Quicklinx: C7R6WS00 Mfr#: TS32GDP520A
For those who extremely care about the road and personal safety, the DrivePro 520 is an ideal dual lens car video recorder that provides its drivers and passengers with optimum protection. Featuring a 130° view angle, a large f/1.8 aperture and 6 glass lens, the front lens captures crystal-clear Full HD 1080P videos with every detail happening on the road. The 180° rotatable rear lens comes with the four infrared LEDs, allowing you to record sharp in-car videos at night or in low light conditions. Easy to install and operate, the DrivePro 520 even includes wireless connectivity to let you stream, download, and share videos whenever needed on your mobile devices.
  • Comprehensively record events with dual lens camera
    To comprehensively protect the road and personal safety, the DrivePro 520 boasts a dual lens camera to record what happens on the road outside and inside your vehicle. With the innovative 6 glass lenses and a large f/1.8 aperture, the front lens can adjust to different lighting conditions to clearly capture events in resolution of Full HD 1080P during daytime and nighttime. The rear lens camera features the 180° rotatable design to ensure that all the important details of your trip and in-car situations can be recorded.
  • Infrared LEDs make videos sharp at night
    Featuring the four Infrared LEDs surrounded by the rear-lens camera, the DrivePro 520 provides ultra-clear in car recording for low light conditions and night vision. When low light conditions are detected, the Infrared LEDs will be automatically turned on to support rear image recording, offering you and passengers a high level in-car safety.
  • An extremely durable microSDHC card for car video recorder use
    Each 32GB microSDHC Class 10 UHS-I 600x memory card included in the DrivePro 520 is designed for car video recorder use. Built with top-tier MLC NAND flash chips, it provides the consistent long-life durability and endurance.
  • Record every critical moment
    In the event of a collision, the DrivePro 520's motion G-Sensor will detect the impact and instantly trigger emergency recording mode. Emergency recording mode protects the current recording, including the critical seconds before the accident, from being overwritten. In addition, If other situations occur outside, you can simply press the accessible emergency button to manually activate emergency recording, protecting you from a false or lawsuit.
  • Instantly view and download videos on mobile devices
    Supported by the free downloadable DrivePro520 App, the DrivePro 520 includes wireless connectivity to let you stream, download, and share videos on a iOS and Android smartphone and tablet - perfect for reporting incidents to insurance companies or the police.
  • GPS receiver to log your driving records
    DrivePro 520's built-in GPS receiver can log GPS coordinates, date and time into the recorded video footage. During an incident, the GPS coordinates can help you precisely locate where you are so as to contact the Emergency Road Service, the police or the insurance company.
  • Convenient snapshot function
    The convenient snapshot feature allows you to take photos while recording video. During an incident, you can also remove DrivePro 520 from the vehicle to capture collision damage on the spot.
Transcend DrivePro 520 - dashboard camera
Dashboard camera - 1080p
Memory Card Slot
microSD card
Wireless Interface
Wi-Fi
Max Video Resolution
1920 x 1080
Lens System
Wide-angle lens f/1.8
Lens System (2nd)
Wide-angle lens - f/2.8
Focus Adjustment
Focus free
Display
LCD display - 2.4"
Real-Time Locations
GPS / GLONASS
Supported Battery
Li-Polymer rechargeable battery - 430 mAh
USB 2.0
9.62 cm x 4.39 cm x 6.45 cm
108 g
Built-in Light
IR illuminator
Sensor Qty
1 CMOS
Widescreen Video Capture
Optical Sensor Type
CMOS
Navigation
GPS/GLONASS receiver
Digital Video Format
H.264, MOV
Image Recording Format
JPEG
1920 x 1080
USB 2.0, IEEE 802.11b/g/n
Connectivity Features
Remote live view
Exposure & White Balance
Exposure Modes
Automatic
White Balance
Automatic
Lens System
Focus Adjustment
Focus free
Max View Angle
130 degree(s)
Lens System (2nd)
Focus Adjustment
Focus free
Additional Features
Additional Features
Built-in speaker
Dashboard Camera Features
Real-Time Locations
GPS / GLONASS
Two adjustable cameras
Display
2.4" LCD display
Display Form Factor
Built-in
Microphone
Microphone Operation Mode
Mono
Connector Type
USB 2.0
Car power adapter, suction cup mount
Battery Type
Integrated
Details
Memory / Storage
Memory Card Slot
microSD card
Supported Memory Cards
microSD Card, microSDHC Card
Memory Card
32 GB microSDHC
Memory Card Included
Memory Card Max Supported Size
32 GB
Video Capture
H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 30 fps
9.62 cm
4.39 cm
6.45 cm
108 g
