DrivePro 100
Day or night, the DrivePro 100 Car Video Recorder is your most reliable eyewitness on the road. With a built-in battery, the recorder gives you an extra 30 seconds of recording in case of power failure, offering maximum assurance. The DrivePro 100's high-quality wide angle 6 glass lenses can capture snapshots and clear Full HD footage for display on a bright 2.4" color LCD screen. Easy to operate, the DrivePro 100 includes the Auto Power On/Off feature and the free-to-download DrivePro Toolbox for Windows for users to easily play the recorded videos on their computer.
Protecting You Day and Night
Featuring a large F/1.8 aperture and high-quality camera lens, the DrivePro 100 can automatically adjust to different lighting conditions to capture all details of an incident, including license plates, during either daytime or nighttime.
Built-in Battery to Ensure Uninterruptible Recording
With a built-in Li-Polymer battery, there's no need to worry about sudden power failure caused by traffic incidents. When the car loses power, DrivePro 100 continues to record for up to 30 seconds to ensure the important evidentce is captured. Alternatively, the DrivePro 100 can be manually activated to record up to 30 minutes on a fully charged battery without a power supply.
Convenient Snapshot Function
The convenient snapshot feature allows you to take photos while recording video. During an incident, you can also remove DrivePro 100 from the vehicle to capture collision damage on the spot.
Sharp and Smooth Images
The DrivePro 100's camera integrates a wide 130° viewing angle and a Full HD imaging sensor for clear and smooth 1080p (30fps) recordings. The 6 glass lenses plus 1 infrared filter lens are designed to prevent fogging from heat generated during extended recordings and to ensure your whole trip is recorded in high clarity.
Record Every Critical Moment
If the DrivePro 100's built-in G-Sensor detects an impact during recording, it will instantly trigger Emergency Recording mode up to 1 minute (30 seconds before and after the incident). Alternatively, you can also activate emergency recording mode manually by pressing the red emergency button; this is useful when situations occur outside the vehicle where you need to collect evidence in case of a fraudulent claim or lawsuit. Video files recorded in emergency mode are protected from being overwritten.
Protecting you day and night
Featuring a large F/1.8 aperture and high-quality camera lens, the DrivePro 100 can automatically adjust to different lighting conditions to capture all details of an incident, including license plates, during either daytime or nighttime. -
Built-in battery to ensure uninterruptible recording
With a built-in Li-Polymer battery, there's no need to worry about sudden power failure caused by traffic incidents. When the car loses power, DrivePro 100 continues to record for several seconds to ensure the important evidence is captured. Alternatively, the DrivePro 100 can be manually activated to record up to 30 minutes on a fully charged battery without a power supply. -
Convenient snapshot function
The convenient snapshot feature allows you to take photos while recording video. During an incident, you can also remove DrivePro 100 from the vehicle to capture collision damage on the spot. -
Sharp and smooth images
The DrivePro 100's camera integrates a wide 130° viewing angle and a Full HD imaging sensor for clear and smooth recordings. The 6 glass lenses plus 1 infrared filter lens are designed to prevent fogging from heat generated during extended recordings and to ensure your whole trip is recorded in high clarity. -
Record every critical moment
- Transcend DrivePro 100 - dashboard camera
- Product Type
- Dashboard camera - 1080p
- Memory Card Slot
- microSD card
- Sensors
- Gyro sensor
- Sensor Resolution
- 3.0 Megapixel
- Lens System
- Wide-angle lens f/1.8
- Display
- LCD display - 2.4"
- Incident Detection
- G-Sensor
- Supported Battery
- Li-Polymer rechargeable battery - 470 mAh (included)
- Interface
- USB 2.0
- 6.31 cm x 3.44 cm x 6.83 cm
- 72.6 g
- 2-year warranty
- Product Type
- Sensor Resolution
- 3.0 Megapixel
- Sensor Qty
- 1 CMOS
- Widescreen Video Capture
- Optical Sensor Type
- CMOS
- Sensors
- Gyro sensor
- Digital Video Format
- H.264, MOV
- Interface
- USB 2.0
Lens System
- Max View Angle
- 130 degree(s)
- Lens Construction
- 6 elements
Additional Features
- Additional Features
- Audio recording, built-in speaker, auto power save, takes photos while film recording
Dashboard Camera Features
- G-Sensor
Display
- 2.4" LCD display
- Display Form Factor
- Built-in
Microphone
- Microphone Operation Mode
- Mono
- Connector Type
- USB 2.0
Software
- Software
- Drivers & Utilities, Transcend DrivePro PC Tool
- Included Accessories
- Car power adapter, suction cup mount
- Battery Type
- Lithium polymer - integrated
- Details
- Battery Life Details
- Video recording - 0.5 hours
Memory / Storage
- Memory Card Slot
- microSD card
- Supported Memory Cards
- microSD Card, microSDHC Card
- Memory Card
- 16 GB microSDHC
- Memory Card Max Supported Size
- 32 GB
- Video Capture
- H.264 - 1920 x 1080 - 30 fps , H.264 - 1280 x 720 - 30 fps
- Limited warranty - 2 years
- 6.31 cm
- 3.44 cm
- 6.83 cm
- 72.6 g
- -20 °C
- 65 °C
