The ixL-S Media Centre is not only a very powerful Media Centre, it's almost near silent - with the unique, specially designed fan less CPU cooling system. The thick aluminium cabinet is beautiful and will look at home in any audio visual system or home theatre.
Not only does it look gorgeous it's very efficient, consuming only 21W when idle.
As it is fan less - not only is it silent, it should outlast any other media centre, as there are no fans to clog up and eventually fail. A media centre is a substantial investment - the ixL-S is wise investment, and one that you will be proud to put on show in your home.
Enjoy all of your media in high definition on the big screen with a range of connectivity.
-Play CDs, DVDs
-Watch / Play Media Files - Movies - Music - Pictures
-Enjoy Internet TV services (IPTV)
-Play big screen games
-Use the system for web browsing or any PC program
The small system unit is a mere 240mm wide and 250mm deep and 110mm high.
To the front you have two USB ports and multi-media card reader and the slot loading CD/DVD. With a IR RX you will be ready to start using your sleek remote hand set immediately.
On the back you will find you have a wide array of Audio/Visual and PC connectivity - including HDMI / DVI - SPDIF / Multi-channel Audio - USB ports - High Speed Networking - eSATA ports.
- Media centre
- Processor Type
- Core i5
- Processor Model
- I5-2400S
- Installed Memory
- 4 GB
- Office Ready PC
- No
- Optical Storage
- DVD-Writer / BD-ROM
- Operating System
- Microsoft Windows 7 Home Premium 64-bit Edition
- Case Style
- Small Form Factor
- Display
- Hard Drive Capacity
- 2 TB
- Processor / Manufacturer
- Intel
- Processor Speed
- 2.5 GHz
- Product Line
- Tranquil ixLS Media Centre PC
