TP LINK Wireless N USB Adapter
Quicklinx: 77RMWS00 Mfr#: TL-WN821N
  • IEEE 802.11n (draft 2.0)
Wireless N USB Adapter TL-WN821N allows you to connect a desktop or notebook computer to a wireless network and access high-speed Internet connection. Comply with IEEE 802.11n, they provide wireless speed up to 300 Mbps, which is beneficial for the online gaming or even HD video streaming.
With MIMO (multiple input, multiple output antennas) technology, it shows more excellent abilities of mitigating data loss over long distances and through obstacles in a small office or a large apartment, even in a steel-and-concrete building. Above all, you could easily pick up the wireless network during long-distance connection where legacy 11 g products may not!
  • Wireless N - speed and range
  • CCA technology - stable wireless signals
    Clear Channel Assessment (CCA) automatically avoids channel conflicts using its clear channel selection feature and fully realizes the advantages of channel binding, greatly enhanced the wireless performance.
  • WPA/WPA2 encryptions - advanced security
    As for the security of WI-FI connection, WEP encryption has been no longer the strongest and safest guards for outside intrusions. TL-WN821N provides WPA/WPA2 encryptions that are created by the Wi-Fi alliance industry group, promoting interpretabilities and security for WLAN, which could effectively and efficiently protect the wireless network.
  • One button security setup
    Compatible with Wi-Fi Protected Setup (WPS), TL-WN821N features quick security setup that allows users to almost instantly setup their security simply by pressing the "QSS" button automatically establishing a WPA2 secure connection, which is more security compared with WEP encryptions. Not only is this faster than normal secure setups but more convenient in that you don't need to remember a password!
  • Bundled CD for easy operation
    TL-WN821N comes with a CD with utility that helps you complete the software installation and wireless network settings, including security configurations and wireless connection, which is convenient for users, even for novice users.
TP-Link TL-WN821N - network adapter - USB 2.0
Network adapter
External
Interface (Bus) Type
USB 2.0
9.4 cm x 2.6 cm x 1.1 cm
802.11b/g, 802.11n (draft 2.0)
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
IEEE 802.11b, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n (draft 2.0)
Microsoft Windows Vista / 2000 / XP
Network adapter
External
USB 2.0
Wireless
IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
MIMO technology
Aerial
Antenna
Internal
Antenna Qty
1
Directivity
Omni-directional
1 x USB 2.0
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
FCC
Software Included
Drivers & Utilities
9.4 cm
2.6 cm
1.1 cm
10 - 90%
