TP LINK Wireless Ceiling Mount DBC/AP
Quicklinx: BLZ8WS00 Mfr#: EAP600
  • IEEE 802.11n
The X-treme SMB EnGenius EAP600 is a concurrent dual-band 2.4+5 GHz wireless-N indoor access point that features high transmit RF power for long range connectivity. With wireless speeds up to 300 Mbps on each radio and a Gigabit port for connecting to a switch or router it's ideal for expanding a network with additional bandwidth to support additional users.
  • Concurrent dual-band 300+300 Mbps supports
    It offers 802.11n dual radio concurrent operation in 2.4 GHz and 5 GHz for maximum wireless throughput performance.
  • High-power, long-range Wi-Fi
    29 dBm for 2.4 GHz, 26 dBm for 5 GHz RF Tx power provides more than twice greater Wi-Fi coverage over mainstream competitors.
  • Aesthetic design enclosure
    "Smoke detector" appearance and easy mounting mechanism with t-rail, ceiling, and wall mount kits.
  • Simplified wireless network management
    Including SNMP based wireless access point management software - EnGenius zone controller.
  • MSSID and VLAN supports
    It ups to 8 BSSIDs per radio with 802.1q VLAN tagging.
  • 4 x internal antennas
    It offers 4 x 5 dBi internal antennas optimizing maximum RF performance.
EnGenius EAP600 - radio access point - Wi-Fi
Radio access point
External - indoor
RAM
64 MB
Flash Memory
8 MB
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Power Over Ethernet (PoE) Supported
PoE
16.15 cm x 16.15 cm x 4.15 cm
280 g
1-year warranty
Radio access point
Ruggedized Design
Indoor
16.15 cm
16.15 cm
4.15 cm
280 g
Processor / Memory / Storage
RAM
64 MB
Flash Memory
8 MB
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, BPSK, QPSK, 16 QAM
Spread Spectrum Method
OFDM
Network / Transport Protocol
TCP/IP, PPTP, L2TP, IPSec, DHCP
Remote Management Protocol
SNMP 1, Telnet, SNMP 3, SNMP 2c, HTTP, CLI
Frequency Band
2.4 GHz
Status Indicators
Power, status, WLAN, LAN
Power over Ethernet (PoE), VLAN support, Syslog support, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, firmware upgradable, MIMO technology, wall mountable, Wi-Fi Multimedia (WMM) support, event log, Quality of Service (QoS), DHCP server, Multiple SSID support, wireless bridge mode, ceiling mountable
Encryption Algorithm
MD5, AES, 128-bit WEP, 64-bit WEP, TLS, PEAP, TTLS, TKIP, WPA, WPA-PSK
Authentication Method
Radio Service Set ID (SSID), Extensible Authentication Protocol (EAP)
IEEE 802.1D, IEEE 802.1Q, IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.11n, IEEE 802.3at
Aerial
Antenna
Internal
Antenna Qty
4
Gain Level
5 dBi
1 x 1000Base-T - RJ-45
1 x network cable
Mounting Kit
Included
IC, FCC
PoE
External power adapter
Software Included
Drivers & Utilities
Limited warranty - 1 year
50 °C
