TP LINK Wi-Fi N450 Gigabit Router with USB port
Quicklinx: BXP0WS00 Mfr#: TL-WR1043ND V3
  • IEEE 802.11n
  • 450Mbps Wireless speed and Gigabit Ethernet ports are ideal for multiple HD video streaming
  • Multi-functional USB 2.0 port - Easily share a printer locally and files & media with networked devices or remotely via FTP server
  • Wireless security encryption easily at a push of WPS Button
Wireless Speed Up To 450Mbps 2.4GHz Set To Maximum
With wireless speeds of up to 450Mbps, the maximum speed available on a 2.4GHz single band, you can enjoy HD video streaming and online gaming with an even more fluid experience than 300Mbps and 150Mbps.
Fully extended coverage
3*5dBi antennas
3 external 5dBi antennas combined with higher quality antenna technology provide users with larger wireless coverage and stronger wireless signal intensity from anywhere in your large home or office.
Blazing Wired Speeds
5 Gigabit Ports + 800Mbps Hardware NAT
With 5 built-in gigabit ports and a Hardware NAT function, the wireless router provides powerful data processing capabilities. Its NAT WAN to LAN throughput can achieve up to 800Mbps+ allowing users to unleash the full potential of their networks.
Easy for Sharing
Multi-functional USB Port
Using the TL-WR1043’s multi-functional USB ports, users can share printers, files and media either throughout the network at home with several different computers or even away. Using the device’s ftp server functions so that you never have to part with your files.
  • Wireless speed up to 450 Mbps 2.4 GHz set to maximum
    With wireless speeds of up to 450 Mbps, the maximum speed available on a 2.4 GHz single band, you can enjoy HD video streaming and online gaming with an even more fluid experience than 300 Mbps and 150 Mbps.
  • Fully extended coverage
    3 external 5 dBi antennas combined with higher quality antenna technology provide users with larger wireless coverage and stronger wireless signal intensity from anywhere in your large home or office.
  • Blazing wired speeds
  • Easy for sharing - multi-functional USB port
    Using the TL-WR1043's multi-functional USB ports, users can share printers, files and media either throughout the network at home with several different computers or even away. Using the device's ftp server functions so that you never have to part with your files.
TP-Link TL-WR1043ND V3 - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
450 Mbps
Network / Transport Protocol
PPTP, L2TP, IPSec, PPPoE
Routing Protocol
Static IP routing
Firewall protection, DMZ port, SPI, DoS attack prevention, dynamic DNS server, MAC address filtering, VPN passthrough, WDS support, URL filtering, IP address filtering, firmware upgradable, virtual server support, DHCP server, DHCP client
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, USB 2.0, IEEE 802.11n, UPnP
22.5 cm x 14.1 cm x 3 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows 2000/XP/Vista/7/8
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
450 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, USB 2.0, IEEE 802.11n, UPnP, FCC Class B certified, RoHS
Status Indicators
Power, link OK, system, status, link/activity
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
Directivity
Omni-directional
Gain Level
5 dBi
External power adapter
Software Included
Drivers & Utilities
22.5 cm
14.1 cm
3 cm
10 - 90% (non-condensing)
