TP LINK WBS510 5GHz 300Mbps Outdoor Wireless Base Station POE
Quicklinx: CM9XWS00 Mfr#: WBS510
  • IEEE 802.11n
TP-LINK's 5 GHz 300 Mbps Outdoor Wireless Base Station is specifically designed to provide an effective solution for outdoor wireless networking applications. With its centralized management platform and high degree of flexibility, it is the ideal choice for providing point-to-point, point-to-multipoint, and outdoor Wi-Fi coverage. The TP-LINK Outdoor Wireless Base Station pairs professional performance with user-friendly design, making it the perfect solution for both business and home users.
Two external RP-SMA antenna interfaces allow the Outdoor Wireless Base Station to integrate seamlessly with TP-LINK's line of sector and dish antennas. Where long- distance wireless data transmission is necessary, the WBS510 can be paired with a TP-LINK dish antenna, allowing it to transfer data over distances of up to 50 km.
Pharos Base Stations works seamlessly with TP-LINK dish and sector antennas to provide efficient PtP and PtMP data transmission. Pharos Base Stations also feature a built-in mount, meaning that no tools are required for installation.
  • Access where you need it most
  • Long-distance wireless data transmission
  • Easy installation, no tools needed
  • Enterprise level hardware design
    To maximize performance and stabilize long distance wireless transmission, the Pharos Series is built with Qualcomm Atheros enterprise level chipsets, high gain-antennas, and high-power amplifiers. In addition to excellent internal components, Pharos Series Base Stations also feature specially designed, weatherproof enclosures and PoE capability. This industry-leading hardware ensures that Pharos Series Base Stations can be deployed in a wide variety of environments, withstanding broad ranges of humidity and temperature.
TP-Link WBS510 - radio access point - Wi-Fi
Radio access point
External - outdoor
1 x Qualcomm MIPS 74KC 560 MHz
RAM
64 MB
Flash Memory
8 MB
IEEE 802.11a, IEEE 802.11n
Frequency Band
5 GHz
Power Over Ethernet (PoE) Supported
PoE
7.5 cm x 3.2 cm x 18.9 cm
Radio access point
Ruggedized Design
Outdoor
7.5 cm
3.2 cm
18.9 cm
Processor / Memory / Storage
Processors Installed
Max Supported Qty
1
RAM
64 MB DDR2 SDRAM
Flash Memory
8 MB
External
Wireless
Data Transfer Rate
300 Mbps
Network / Transport Protocol
PPTP, L2TP, PPPoE, DHCP
Remote Management Protocol
SNMP 2c, HTTP, HTTPS, SSH
Frequency Band
5 GHz
Repeating mode, ALG support, manageable, DFS support, Wireless Distribution System (WDS) support, Multiple SSID support, wireless bridge mode, bandwidth control, Wireless Client Mode, pole mountable, Stateful Packet Inspection Firewall (SPIF), IP-MAC binding, static routing, 15KV ESD Protector
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
1 x 1000Base-T (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45 , 2 x aerial - RP-SMA
FCC, RoHS, IP65
PoE
Power injector
Software Included
Drivers & Utilities
-30 °C
70 °C
10 - 90% (non-condensing)
