Outdoor 2.4GHz 300Mbps Wireless Base Station up to 30dBm 802.11b/g/n 2 ext. antenna interfaces 10/100Mbps 110/100/1000Mbps LAN Weatherproof Passive PoE
TP-LINK MAXtream TDMA technology
As network scale increases, wireless competition and collisions among CPEs will be so fierce that the real throughput of the network will drop, resulting in a serious impact on end-user experience, to mitigate these effects, TP-LINK's Pharos series uses MAXtream TDMA technology. -
Pharos Control - centralized management system
Pharos also comes equipped with centralized management software that helps users easily manage all the devices in their network from a single PC - Pharos Control. Functions like device discovery, status monitoring, firmware upgrading, and network maintenance can be managed using Pharos Control. -
PharOS
User-friendly web-based management system allows professionals to do more specific configurations.
- TP-Link WBS210 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External - outdoor
- Processor
- 1 x Qualcomm MIPS 74KC 560 MHz
- RAM
- 64 MB
- Flash Memory
- 8 MB
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Power Over Ethernet (PoE) Supported
- PoE
- 7.5 cm x 3.2 cm x 18.9 cm
- Ruggedized Design
- Outdoor
- 7.5 cm
- 3.2 cm
- 18.9 cm
Processor / Memory / Storage
- Processors Installed
- Max Supported Qty
- 1
- RAM
- 64 MB DDR2 SDRAM
- Flash Memory
- 8 MB
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 300 Mbps
- PPTP, L2TP, PPPoE, DHCP
- Remote Management Protocol
- SNMP 2c, HTTP, HTTPS, SSH
- Frequency Band
- 2.4 GHz
- Repeating mode, ALG support, manageable, DFS support, Wireless Distribution System (WDS) support, Multiple SSID support, wireless bridge mode, bandwidth control, Wireless Client Mode, pole mountable, Stateful Packet Inspection Firewall (SPIF), IP-MAC binding, static routing, 15KV ESD Protector
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
- 1 x 1000Base-T (PoE) - RJ-45 , 1 x 100Base-TX - RJ-45 , 2 x aerial - RP-SMA
- FCC, RoHS, IP65
- PoE
- Power Device
- Power injector
- Software Included
- Drivers & Utilities
- -30 °C
- 70 °C
- 10 - 90% (non-condensing)
