TP LINK USB2 MFP Print/Storage server
Quicklinx: 77S3WS00 Mfr#: TL-PS310U
The TP-LNK MFP and Storage Server TL-PS310U is ideal for sharing USB connected devices across a home or office network.
The device is compatible with the majority of printers and multi-function printers on the market and allows for seamless sharing and management of those devices with network connected computers. The device is also capable of operating with up to four USB based devices such as scanners, flash drives, speakers, and webcams with a USB dock connected to the server. These devices may be accessed from across the network and even wirelessly when the Server is connected to a wireless router.
Great Compatibility
The TL-PS310U is compatible with the majority of MFP and otherUSB devices on the market. Tested with over 200 different printer models, our TL-PS310U offers class-leading device compatibility. You will find that the TL-PS310U is an excellent choice for your home or office printing requirements.
Easier Configuration with Higher Efficiency
The totally new interface provides a much easy and intuitive way to operate your print server. You can easily manage and configure our TL-PS310U through the interface even you are a novice user. Turn it on and Leave it alone. With the Auto-Connect function, you can just turn on your Utility and choose the "Connect Automatically for Printing" function and the TL-PS310U will finish the printing job for you. It will automatically connect to your printer and will deal any printing jobs on hand leaving you with time to grab a coffee.
WINDOWS 7 Supported
With the upgrade of the firmware and the new Utility, TL-PS310U now can work perfectly on the WINDOWS 7 operating system. Through the new Utility, you can easily manage the printer and other USB device while working on WINDOWS 7.
  • Great compatibility
    It is compatible with the majority of USB devices on the market.
  • Easy to use
    Ease setup with installation wizard simply by several clicks.
  • Expandable application
    Share up to 4 USB devices by connecting to a USB hub.
TP-Link TL-PS310U - print server - USB 2.0
Print server
External
Interface (Bus) Type
USB 2.0
5.6 cm x 5.2 cm x 2.3 cm
10Mb LAN, 100Mb LAN
Network / Transport Protocol
TCP/IP, DHCP
DC 5 V
Microsoft Windows Vista / 2000 / XP
Print server
External
USB 2.0
Wired
Ethernet, Fast Ethernet
TCP/IP, DHCP
Remote Management Protocol
HTTP
Status Indicators
Status
Firmware upgradable
1 x Ethernet 100 - RJ-45
1 x USB 2.0
FCC
Power adapter - external
DC 5 V
5.6 cm
5.2 cm
2.3 cm
50 °C
0 - 70%
77S3 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.05
