The USB 3.0 to Gigabit Ethernet adapter UE300 adds Gigabit Ethernet network connectivity to your desktops and notebooks through a USB 3.0 port. It transfers your files at ultrafast speed over an Ethernet port.
High-speed data transfer
Equipped with USB 3.0 ports and Gigabit Ethernet port, UE300 provides a high-speed data transfer rate. -
Connect to Gigabit Ethernet network
UE300 adds your devices connectivity to Gigabit Ethernet network. -
Compact and portable design
Compact design with a retractable cable makes it an ideal on the go.
- TP-Link UE300 - network adapter - USB 3.0 - Gigabit Ethernet
- Network adapter
- Form Factor
- External
- Interface (Bus) Type
- SuperSpeed USB 3.0
- Ports
- Gigabit Ethernet
- 2.6 cm x 7.1 cm x 1.62 cm
- Cabling Type
- Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
- Data Link Protocol
- 10Mb LAN, 100Mb LAN, 1GbE
- Data Transfer Rate
- 1 Gbps
- Processor
- Realtek Semiconductor RTL8153
- USB 1.1, USB 2.0, USB 3.0
- System Requirements
- Linux, Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Microsoft Windows Vista / XP / 7 / 8 / 8.1, Apple MacOS X 10.10
- Network adapter
- Form Factor
- External
- Ports
- Gigabit Ethernet
- Connectivity Technology
- Wired
- Cabling Type
- 1 Gbps
- USB powered
Processor / Memory
- Processor
- 1 x 1000Base-T - RJ-45 - female
- Plug and Play
- OS Required
- 2.6 cm
- 7.1 cm
- 1.62 cm
C2G 2m USB 2.0 A/B Cable - Black | In Stock | £3.61 |
