TP LINK USB 3.0 to Gigabit Ethernet Adapter
Quicklinx: BRPMWS00 Mfr#: UE300
More than 50 In Stock
£12.64 ex VAT
£15.16 inc VAT
The USB 3.0 to Gigabit Ethernet adapter UE300 adds Gigabit Ethernet network connectivity to your desktops and notebooks through a USB 3.0 port. It transfers your files at ultrafast speed over an Ethernet port.
  • High-speed data transfer
    Equipped with USB 3.0 ports and Gigabit Ethernet port, UE300 provides a high-speed data transfer rate.
  • Connect to Gigabit Ethernet network
    UE300 adds your devices connectivity to Gigabit Ethernet network.
  • Compact and portable design
    Compact design with a retractable cable makes it an ideal on the go.
TP-Link UE300 - network adapter - USB 3.0 - Gigabit Ethernet
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
2.6 cm x 7.1 cm x 1.62 cm
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX, Ethernet 1000Base-T
10Mb LAN, 100Mb LAN, 1GbE
Data Transfer Rate
1 Gbps
Realtek Semiconductor RTL8153
USB 1.1, USB 2.0, USB 3.0
Linux, Apple MacOS X 10.6, Apple MacOS X 10.5, Apple MacOS X Lion 10.7, Apple OS X 10.8 Mountain Lion, Apple OS X 10.9 Mavericks, Microsoft Windows Vista / XP / 7 / 8 / 8.1, Apple MacOS X 10.10
Network adapter
External
SuperSpeed USB 3.0
Ports
Gigabit Ethernet
Wired
Cabling Type
Data Transfer Rate
1 Gbps
USB powered
Processor / Memory
1 x 1000Base-T - RJ-45 - female
Plug and Play
2.6 cm
7.1 cm
1.62 cm
BRPM C2G 2m USB 2.0 A/B Cable - Black In Stock £4.20
BRPM C2G 5m USB 2.0 A/B Cable - Black In Stock £5.74
Brand: TP LINK
