The TL-WA855RE connects to your router wirelessly, strengthening and expanding its signal into areas it can't reach on its own. Featuring two external antennas with MIMO technology, the TL-WA855RE boosts speeds and increases efficiency throughout the network.
Boost Wi-Fi coverage
The TL-WA855RE boosts your existing Wi-Fi range and delivers faster wireless speed in hard-to-reach areas, providing reliable connections for laptops, smartphones, tablets and other wireless-enabled devices. -
Reliable connection
Two external antennas with MIMO technology for better Wi-Fi coverage and reliable wireless connections. -
Ease of use
Expanding your network should be easy. The intelligent signal indicator LED provides a simple, color-coded indication of whether your range extender is too close to or too far from the main router.
- TP-Link TL-WA855RE 300Mbps Mini Wireless N Range Extender - Wi-Fi range extender - Wi-Fi
- Form Factor
- External
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- OS Required
- UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7, Windows 8 / 8.1, Windows 10
- 5.2 cm x 3.4 cm x 6.5 cm
- 5.2 cm
- 3.4 cm
- 6.5 cm
- Form Factor
- External
- Connectivity Technology
- Wireless, wired
- Data Transfer Rate
- 300 Mbps
- Frequency Band
- 2.4 GHz
- Status Indicators
- Signal strength
- MIMO technology, Wi-Fi Protected Setup (WPS), reset button
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
- IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
- Antenna
- External integrated
- Antenna Qty
- 2
- 1 x 100Base-TX - RJ-45
- Cables Included
- 1 x network cable
- FCC, RoHS
- Power Device
- Internal power supply
- 3 Watt
- OS Required
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey | In Stock | £4.30 |
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.80 |
C2G 10m Cat6 550 MHz Snagless Patch Cable - Black | In Stock | £14.24 |
