TP LINK Universal Range Extender with External Antenna
Quicklinx: BXP1WS00 Mfr#: TL-WA855RE
Type: Wi-Fi range extender
Connectivity: Wireless, Wired
Speed: 300Mbps
Protocol: Fast Ethernet, IEEE 802.11b, Ethernet, IEEE 802.11g + 1 more
Compatibility: Mac, Unix, PC
  • IEEE 802.11n
£15.40 ex VAT
£18.48 inc VAT
The TL-WA855RE connects to your router wirelessly, strengthening and expanding its signal into areas it can't reach on its own. Featuring two external antennas with MIMO technology, the TL-WA855RE boosts speeds and increases efficiency throughout the network.
  • Boost Wi-Fi coverage
    The TL-WA855RE boosts your existing Wi-Fi range and delivers faster wireless speed in hard-to-reach areas, providing reliable connections for laptops, smartphones, tablets and other wireless-enabled devices.
  • Reliable connection
    Two external antennas with MIMO technology for better Wi-Fi coverage and reliable wireless connections.
  • Ease of use
    Expanding your network should be easy. The intelligent signal indicator LED provides a simple, color-coded indication of whether your range extender is too close to or too far from the main router.
TP-Link TL-WA855RE 300Mbps Mini Wireless N Range Extender - Wi-Fi range extender - Wi-Fi
External
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7, Windows 8 / 8.1, Windows 10
5.2 cm x 3.4 cm x 6.5 cm
5.2 cm
3.4 cm
6.5 cm
External
Wireless, wired
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
Status Indicators
Signal strength
MIMO technology, Wi-Fi Protected Setup (WPS), reset button
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna
External integrated
Antenna Qty
2
1 x 100Base-TX - RJ-45
1 x network cable
FCC, RoHS
Internal power supply
3 Watt
10 - 90% (non-condensing)
BXP1 C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
BXP1 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
Connectivity: Wired
Speed: 300Mbps
Protocol: IEEE 802.11b
Protocol: Ethernet
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: Unix
Compatibility: PC
Antennas: 2
Brand: TP LINK
