TP LINK UH720 USB 3.0 7-Port Hub with 2 Charging Ports
Quicklinx: B1DBWS00 Mfr#: UH720
Type: USB Hub
Interface: SuperSpeed USB 3.0
Speed: 5Gbps
Ports: 7
Form Factor: External
£27.18 ex VAT
£32.61 inc VAT
The UH720 USB Hub is a great choice to expand the USB ports of your computer for data transfer when you need to connect USB drives, USB mice, printers or other devices simultaneously. USB 3.0 ports offer transfer speeds of up to 5Gbps, 10 times faster than USB 2.0. Featuring two exclusive 5V 2.4A charging ports, the hub is able to satisfy the demands of all your mobile devices.
High Speed Data Transfer
Equipped with USB 3.0 ports, UH720 provides a data transfer rate of up to 5Gbps, 10 times faster than USB 2.0.
Greatly Expand Your USB Ports
UH720 adds PC 7 additional USB ports to your PC, making it unnecessary to switch between devices.
Super-fast, Smart Charging
Two exclusive 2.4A charging ports supply enough current for all kinds of mobile devices. The intelligent chip recognizes connected devices and adjusts the power to match output, allowing you to charge any device at full speed.
Safe and Reliable
UH720's multiple protections avoid any potential harm to your connected devices no matter if you're transferring data or charging devices.
  • High speed data transfer
  • Greatly expand your USB ports
  • Super-fast, smart charging
  • Safe and reliable
TP-Link UH720 - hub - 7 ports
Hub - 7 ports
Subtype
USB
Ports
7 x SuperSpeed USB 3.0
Hot swap module replacement
USB 1.1, USB 2.0, USB 3.0
16.5 cm x 6.55 cm x 1.75 cm
Linux, Apple MacOS X, Microsoft Windows
Hub - 7 ports
Enclosure Type
Desktop
Subtype
USB
Ports
1 x VIA VL812
7 x USB 3.0 Type A , 2 x USB (power only) 2.4A charging port , 1 x micro-USB 3.0 Type B
External power adapter
1 x USB cable - 1 m
Plug and Play
16.5 cm
6.55 cm
1.75 cm
Type: USB Hub
Speed: 5Gbps
Ports: 7
Brand: TP LINK
