TP LINK TP-LINK TX401 V1 Network Adapter
Quicklinx: FZ64WS00 Mfr#: TX401
Wired / Wireless: Wired
Protocol: 10 Gigabit Ethernet
Form Factor: Plug-in card
Compatibility: [N/A]
Type: Network adapter
10 In Stock
£89.63 ex VAT
£107.55 inc VAT
With fast Internet access, your gaming will be fully optimized with a large boost in speed, latency, and responsiveness. Large-sized game downloads, seamless live streaming, and massive data backups via the cloud are as easy as choosing your character.
  • Local data transmissions in seconds
    For local connections, a 10 Gigabit Ethernet PCIe adapter helps build a lightning fast transport channel between a central server and other working machines in your local network. Local data transmissions will be a breeze for you as you handle bandwidth-intensive tasks easily at your home or office.
  • Versatile, multi-speed compatibility
    The Ethernet port automatically negotiates between higher and lower speed connections, allowing you to upgrade to 10 Gigabit Ethernet networking smoothly.
  • A bandwidth buff for gaming
    QoS technology ensures enough bandwidth and avoids network congestion for PC gaming. It delivers prioritized performance for gamers.
TP-Link TX401 - V1 - network adapter - PCIe 3.0 x4 - 1/2.5/5/10GBase-T x 1
Network adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express 3.0 x4
Ports
2.15 cm x 12.08 cm x 9.82 cm
Cabling Type
Ethernet 100Base-TX, Ethernet 1000Base-T, Ethernet 10GBase-T, Ethernet 2.5GBase-T, Ethernet 5GBase-T
10GbE
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.3x, IEEE 802.3an, IEEE 802.3az, IEEE 802.3bz
Linux, Microsoft Windows 7 / 8 / 8.1 / 10, Microsoft Windows Server 2019
Network adapter
PCI Express 3.0 x4
Ports
Wired
Cabling Type
10 Gigabit Ethernet
Status Indicators
Link/activity
Auto-negotiation, half duplex mode, full duplex mode, QoS
1 x 1/2.5/5/10GBase-T - RJ-45
Low-profile bracket
1 x network cable (external) - 1.5 m
FCC, RoHS
Software Included
Drivers & Utilities
2.15 cm
12.08 cm
9.82 cm
10 - 90% (non-condensing)
Brand: TP LINK
