The EAP's "ceiling lamp" appearance and easy mounting design with chassis make it easy to be integrated seamlessly into any wall or ceiling surface to blend in with most interior decorations.
EAP series APs support Power over Ethernet (PoE) to make deployment effortless and flexible. The free controller software allows administrators to easy manage up to hundreds of EAPs through a single IP to like an Access Controller.
Flexible placement
The EAP's "ceiling lamp" appearance and easy mounting design with chassis make it easy to be integrated seamlessly into any wall or ceiling surface to blend in with most interior decorations. EAP series APs support Power over Ethernet (PoE) to make deployment effortless and flexible. -
Business class wireless
Gigabit Ethernet port ensures high-speed Internet access. -
Efficient guest authentication captive portal
Captive portal provides one convenient method of authentication for Wi-Fi guests. A captive portal requires users to perform certain actions before network access is allowed. The required action must be verified by an external portal server or customized database by the administrator, which can be simply viewing and agreeing to an acceptable use policy, or entering a user ID and password. -
Designed for business performance
EAP220 is specially designed for the high-density, most demanding business environments, including schools, hotels, and enterprises. -
Load balance
Load balance ensures large numbers of users have smooth network experiences in large business networks. -
Dustproof design
Prevents dust from dropping onto the PCB through bypass louver, which ensures long-term, unhindered operation. -
Quality of Service (QoS)
It prioritizes data, voice, and video applications to ensure time-sensitive traffic takes priority over all other traffic.
- TP-Link Omada EAP220 - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz, 5 GHz
- OS Required
- Microsoft Windows Vista / XP / 7 / 8
- Power Over Ethernet (PoE) Supported
- PoE
- 18 cm x 18 cm x 4.75 cm
- 18 cm
- 18 cm
- 4.75 cm
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 600 Mbps
- Remote Management Protocol
- SNMP 1, Telnet, SNMP 2c, HTTP, HTTPS, CLI
- Frequency Band
- 2.4 GHz, 5 GHz
- Load balancing, VLAN support, Syslog support, manageable, E-mail alert, MAC address filtering, wall mountable, Wi-Fi Multimedia (WMM) support, Quality of Service (QoS), Multiple SSID support, reset button, ceiling mountable, security lock slot (cable lock sold separately)
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA-PSK, WPA2-PSK, WPA2-Enterprise
- Authentication Method
- RADIUS
- IEEE 802.11b, IEEE 802.11a, IEEE 802.3af, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n
Aerial
- Antenna
- Internal
- Antenna Qty
- 4
- Directivity
- Omni-directional
- Gain Level
- 4 dBi
- 1 x 1000Base-T (PoE) - RJ-45 , 1 x management (RS-232) - RJ-45
- UL 2043, FCC, RoHS
- PoE
- Power Device
- External power adapter
- 9.6 Watt
- Software Included
- Drivers & Utilities
- OS Required
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
