The MC200CM is a media converter designed to convert 1000BASE-SX fiber to 1000Base-T copper media or vice versa. Designed under IEEE802.3ab 1000Base-T and IEEE802.3z 1000Base-SX standards, the MC200CM is designed for use with multi-mode fiber cable utilizing the SC-Type connector. The MC200CM supports shortwave (SX) laser specification at a full wire speed forwarding rate. It works at 850nm on both transmitting and receiving data.
Other features of this module include the ability to be used as a stand alone device (no chassis required) or with TP-LINK's 19'system chassis, Auto MDI/MDI-X for TX port, and front panel status LEDs. The MC200CM will transmit at extended fiber optic distances utilizing multi-mode fiber up to 0.55 kilometers.
Efficient data transfer
With a data transfer rate of 1 Gbps, the TP-Link MC200CM V5 provides quick communication between devices, making it an ideal solution for high-speed networking. -
Versatile connectivity options
Featuring RJ-45 and SC multi-mode connectors, this media converter allows for flexible connections to accommodate different networking devices and configurations. -
Robust environmental handling
Built to operate in a range of 0°C to 40°C with humidity levels from 10% to 90%, this device is capable of functioning in a variety of environments, ensuring reliable performance. -
Easy setup features
With features like auto-negotiation and auto-uplink, installation and configuration of the MC200CM V5 are simple and user-friendly, reducing setup time. -
Durable housing design
Constructed with a metal housing, this media converter is designed to withstand various environmental conditions while maintaining its performance integrity.
- TP-Link MC200CM V5 - fibre media converter - 1GbE
- Fibre media converter - RJ-45 / SC multi-mode
- Form Factor
- External
- Cabling Type
- 1000Base-SX, 1000Base-T
- Data Transfer Rate
- 1 Gbps
- Optical Wave Length
- 850 nm
- Data Link Protocol
- 1GbE
- Max Transfer Distance
- 550 m
- 9.45 cm x 7.3 cm x 2.7 cm
- Designed For
- P/N: TL-MC1400, TL-SG3210XHP-M2 V2.6, TL-SG3452XP V1
- Form Factor
- External
- Connectivity Technology
- Wired
- Cabling Type
- 1GbE
- 1 Gbps
- 850 nm
- 550 m
- Status Indicators
- Power, link/activity
- Metal housing, auto-negotiation, auto-uplink (auto MDI/MDI-X)
- IEEE 802.3ab, IEEE 802.3z, IEEE 802.3x
- 1 x Ethernet 1000Base-T - RJ-45 female , 1 x Ethernet 1000Base-SX - SC multi-mode female x 2
- FCC, RoHS
- Power Device
- External power adapter
- 9.45 cm
- 7.3 cm
- 2.7 cm
- 0 °C
- 40 °C
- 10 - 90%
- Designed For
