TP LINK TP-LINK Archer T9UH Network Adapter
Quicklinx: D5GQWS00 Mfr#: ARCHER T9UH
Wired / Wireless: Wireless
Protocol: IEEE 802.11n, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g + 1 more
Form Factor: External
Compatibility: PC
Type: Network adapter
  • Windows 8 (32/64 bits)
  • IEEE 802.11n
  • Windows 8.1 (32/64 bits)
£44.28 ex VAT
£53.13 inc VAT
The Archer T9UH lets your PC or laptop take full advantage of the high-speed Wi-Fi created by AC1900 dual band routers. Enjoy connections 3x faster than Wireless N with Wireless AC technology. The Archer T9UH supports dual band Wi-Fi - use the 5GHz band for lag-free gaming and HD streaming, and the 2.4GHz band for video calls and shopping online.
  • Faster connections with AC1900 speed
  • Do more with dual band Wi-Fi
  • Stronger coverage with high-gain antennas
    With four high-gain antennas, the Archer T9UH creates a stable Wi-Fi connection across your home, even when your router is on a different floor.
  • Beamforming for efficient Wi-Fi
    The Archer T9UH supports beamforming, helping create stronger connections with beamforming-capable routers for higher speeds across greater distances.
  • Easy use with a flexible design
    A 3ft. USB 3.0 cable makes it easy to find a spot for the Archer T9UH in your workspace, and the adapter can be effortlessly attached removed from your computer as needed.
TP-Link Archer T9UH - network adapter - USB 3.0
Network adapter
External
Interface (Bus) Type
SuperSpeed USB 3.0
10.053 cm x 3.66 cm x 1.43 cm
Wi-Fi 5
Data Transfer Rate
1.9 Gbps
Frequency Band
2.4 GHz, 5 GHz
No CPU
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, IEEE 802.11ac
Linux, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits), Windows 8.1 (32/64 bits), Apple MacOS X 10.7 - 10.10, Windows 10 (32/64 bits)
Network adapter
External
SuperSpeed USB 3.0
Wireless
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac
Data Transfer Rate
1.9 Gbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 256 QAM, 16 QAM, OFDM
Frequency Band
2.4 GHz, 5 GHz
Ad-Hoc Mode, WPS
Aerial
Antenna
Internal
Antenna Qty
4
Directivity
Omni-directional
Processor / Memory
No CPU
USB cradle
Encryption Algorithm
128-bit WEP, 64-bit WEP, WPA-PSK, WPA2-PSK
FCC, RoHS
Software Included
Drivers & Utilities
10.053 cm
3.66 cm
1.43 cm
10 - 90% (non-condensing)
Protocol: IEEE 802.11b
Protocol: IEEE 802.11a
Protocol: IEEE 802.11g
Protocol: IEEE 802.11ac
Compatibility: PC
Brand: TP LINK
