TP Link Archer AX73 V1 Wireless Router - 802.11a/b/g/n/ac/ax - Desktop
Quicklinx: G6WFWS00 Mfr#: ARCHER AX73
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11n, Fast Ethernet, IEEE 802.11a, Ethernet + 5 more
Speed: 540
Rackmount or External: Desktop
  • IEEE 802.11n
12 In Stock
£85.06 ex VAT
£102.07 inc VAT
Gigabit WiFi for 8K Streaming – 5400 Mbps WiFi for faster browsing, streamings, and downloading, all at the same time.
Fully Featured Wi-Fi 6 – Equips with the top structure of 4T4R and HT160 on the 5 GHz band to enable 4.8 Gbps ultra-fast connection.
Connect 200+ Devices – Supports MU-MIMO and OFDMA to reduce congestion and quadruple the average throughput.‡**
Extensive Coverage – 6× antennas and Beamforming ensure broad coverage.
HomeShield – TP-Link's premium security services keep your home network safe with cutting-edge features for network and IoT protection.*
More Vents, Less Heat – Improved vents area unleash the full power of the whole machine.
USB Sharing – 1× USB 3.0 port enables easy media sharing and private cloud building.
Easy Setup – Set up the router in minutes with Tether app.
  • Wi-Fi 6 upgrades everything
    The advanced Wi-Fi technology brings faster speeds, less lag, and higher capacity, enabling more simultaneous connections on your home network.
  • Warp speed for smooth 8K streaming
    Drastically improved speeds enable streaming, fast downloading, and gaming, all at the same time. Need to go faster? Hop on 5 GHz with full speed-boosting features to stream multiple 8K videos without lagging.
  • Extensive Wi-Fi coverage with advanced technology
    Enjoy stable Wi-Fi connections, even in the kitchen and bedroom. High-power FEM, 6x Antennas, Beamforming, and 4T4R structures combine to adapt Wi-Fi coverage to perfectly fit your home and concentrate signal strength towards your devices.
  • Connect 200+ devices
    Easily handle dozens of devices streaming and gaming at the same time - OFDMA and MU-MIMO combine to future-proof your home network by providing greater capacity to connect more devices.
  • Designed to be cool
    The slant rectangle atop of the scaled armor design provides a contemporary aesthetic. The vent design takes up 167 cm2 (25 inch2) of its top surface for improved heat dissipation, unleashing the whole machine's full power.
TP-Link Archer AX73 - V1 - wireless router - Wi-Fi 6 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Network / Transport Protocol
PPTP, L2TP, PPPoE, FTP, DHCP, DDNS, IPv4, IPv6
Routing Protocol
IGMP, static IP routing
NAT support, IGMP snooping, SPI, DFS support, URL filtering, parental control, Access Point operational mode, firmware upgradable, ACL support, QoS, virtual server support, WPS, FTP server, static IP mode, port forwarding, reset button, Apple Time Machine compatible, port triggering, dynamic IP mode, IP-MAC binding, DHCP client, IGMP proxy, beamforming technology, dual band, router mode, Airtime Fairness, 4x4 MU-MIMO technology, DMZ support, PPTP server, OFDMA, OpenVPN server, IPTV support, WPS button
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6
27.25 cm x 14.72 cm x 4.92 cm
1.49 kg
3-year warranty
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Routing Protocol
Encryption Algorithm
WPA, WPA2, WPA-Enterprise, WPA2-Enterprise, WPA3
Wi-Fi Rating
AX5400
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.1x, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, Wi-Fi CERTIFIED 6, FCC, RoHS
1.5 GHz
Line Properties
Line Coding Format
OFDMA
WAN / LAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN / LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 3.0: 1 x
Aerial
Aerial
External integrated
Antenna Qty
6
External power adapter
1 x network cable
27.25 cm
14.72 cm
4.92 cm
1.49 kg
Limited warranty - 3 years
10 - 90% (non-condensing)
Standards: Fast Ethernet
Standards: IEEE 802.11a
Standards: Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11ax (Wi-Fi 6)
Standards: IEEE 802.11ac
Speed: 540
Brand: TP LINK
