TP LINK TP-LINK Archer AX20 Wireless Router - 802.11a/b/g/n/ac/ax
Quicklinx: FZ62WS00 Mfr#: Archer AX20
Type: Wireless router
Connection Type: WAN/LAN
Standards: IEEE 802.11n, IEEE 802.11a, Ethernet, Fast Ethernet + 5 more
Speed: 1.8Gbps
Rackmount or External: Desktop
  • IEEE 802.11n
£80.80 ex VAT
£96.96 inc VAT
Equipped with Wi-Fi 6 for faster speeds, greater capacity, and reduced network congestion. Enjoy smooth streaming, downloading, and gaming all without buffering. Wi-Fi 6 technology communicates more data to more devices using OFDMA and MU-MIMO technology while simultaneously reducing lag.
  • Extensive coverage
    Beamforming, independent FEM, and four antennas combine to deliver focused reception to devices far away.
  • Increased battery life
    Target wake time technology reduces your devices' power consumption to extend their battery life.
  • USB easy sharing
    A USB 2.0 port enables easy file sharing within your network or building private cloud storage.
  • WPA3 technology
    Powerful encryption technology eliminates brute-force attacks and provides better security.
TP-Link Archer AX20 - wireless router - Wi-Fi 6 - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, IEEE 802.11ac, IEEE 802.11ax (Wi-Fi 6)
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.8 Gbps
Performance
Maximum data rate (2.4 GHz): 574 Mbps , Maximum data rate (5 GHz): 1201 Mbps
Network / Transport Protocol
PPPoE, DHCP
Routing Protocol
Static IP routing
NAT support, parental control, DHCP server, port forwarding, reset button, port triggering, DHCP client, MU-MIMO technology, guest access, DMZ support, DynDNS
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax
26.02 cm x 13.5 cm x 3.86 cm
UNIX, Apple MacOS, Novell NetWare, Linux, Windows 8.1 / 10, Microsoft Windows 98SE/2000/NT/XP/Vista/7/8
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1.8 Gbps
Performance
PPPoE, DHCP
Routing Protocol
Static IP routing
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP, WPA3
Wi-Fi Rating
AX1800
IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, UPnP, IEEE 802.11ac, IEEE 802.11ax, FCC, RoHS
1 x 1.5 GHz
Line Properties
Line Coding Format
OFDMA
LAN: 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN: 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
Aerial
External
Antenna Qty
4
External power adapter
1 x network cable
26.02 cm
13.5 cm
3.86 cm
Standards: IEEE 802.11a
Standards: Ethernet
Standards: Fast Ethernet
Standards: Gigabit Ethernet
Standards: IEEE 802.11b
Standards: IEEE 802.11g
Standards: IEEE 802.11ac
Standards: IEEE 802.11ax (Wi-Fi 6)
Speed: 1.8Gbps
Brand: TP LINK
