TP LINK TP-Link 16 Port Gigabit Easy Smart Switch
Quicklinx: 8TYVWS00 Mfr#: TL-SG1016DE
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: 1Gbps
Managed: Yes
POE: No
£74.38 ex VAT
£89.25 inc VAT
The TL-SG1016DE 16-Port Gigabit Easy Smart switch is an ideal upgrade from an unmanaged switch, designed for Small and Medium Business networks that require simple network management. Network administrators can effectively monitor traffic via Port Mirroring, Loop Prevention and Cable Diagnostics features. To optimize traffic on your business network, TL-SG1016DE offers both port and tag based QoS to keep latency-sensitive traffic moving smoothly and jitter-free. Additionally, port-based, tag-based and MTU VLAN can improve security and meet more network segmentation requirements. Moreover, with its innovative energy-efficient technology, the TL-SG1016DE can save up to 40% of power consumption, making it an Eco-friendly solution for your business network.
  • Simple & effective management
    TP-LINK's Gigabit Easy Smart switch, TL-SG1016DE offers network monitoring for users to observe traffic behavior. With Port Mirroring, Loop Prevention and Cable Diagnostics features, TL-SG1016DE can identify and even locate connection problems on your business network. Moreover, administrators can designate the priority of the traffic based on Port Priority and 802.1P Priority, to ensure that voice and video are always clear, smooth and lag-free. Additionally, to improve security and network performance, TL-SG1016DE supports MTU VLAN, port-based VLAN and 802.1Q-based VLAN functions. TL-SG1016DE is an upgrade from the Plug-and-Play unmanaged switch, delivering great value while empowering your network and similarly delivering great value to the end user.
  • Go green with your Ethernet
    You now have the choice to go green when upgrading to a gigabit network! This TL-SG1016DE 16-Port Gigabit Easy Smart switch features the latest energy-efficient technologies that can greatly expand your network's capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network.
  • Ease of use
    TL-SG1016DE is easy to use and manage. Auto MDI/MDI-X crossover on all ports eliminate the need for crossover cables or uplink ports. Auto-negotiation on each port senses the link speed of a network device (either 10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance. Its compact size makes it ideal for desktops with limited space while also being rack-mountable, convenient and safe. Dynamic LED lights provide real-time work status display and basic fault diagnosis.
TP-Link JetStream TL-SG1016DE - switch - 16 ports - Managed - rack-mountable
Switch - 16 ports - Managed
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Switching capacity: 32 Gbps , Forwarding performance: 23.8 Mpps
Virtual interfaces (VLANs): 32
MAC Address Table Size
8K entries
Jumbo Frame Support
10240 bytes
Auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, port mirroring, store and forward, QoS, fanless, loop prevention
IEEE 802.3, IEEE 802.3u, IEEE 802.1Q, IEEE 802.3ab, IEEE 802.3x, IEEE 801.1p
29.4 cm x 18 cm x 4.4 cm
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000 / NT, Microsoft Windows Vista / XP / 7 / 8
Enclosure Type
Rack-mountable 1U
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
10240 bytes
16 x 1000Base-T RJ-45
Internal power supply
Rack Mounting Kit
Included
FCC, RoHS
29.4 cm
18 cm
4.4 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
8TYV C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
8TYV C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £4.71
8TYV C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £14.87
Ports: 16
Managed: Yes
POE: No
Brand: TP LINK
