TP LINK TL-WR940N Wireless N300 Router
Quicklinx: BJ7FWS00 Mfr#: TL-WR940N
  • IEEE 802.11n
TL-WR940N is a combined wired / wireless network connection device designed specifically for small business and home office networking requirements. With MIMO technology, TL-WR940N creates an exceptional and advanced wireless performance, making it ideal for streaming high-definition video, VoIP calls and online gaming. Also, WPS button on the sleek and fashionable exterior ensures connection encryptions, preventing the network from outside intrusions.
  • Reliable wireless connection
    TL-WR940N shows excellent abilities of mitigating data loss over long distances and through obstacles in a small office or a large apartment, even in a steel-and-concrete building. Above all, you could easily pick up the wireless network during long-distance connection.
  • Better wireless performance
    The router has the speed to work smoothly with almost any bandwidth-intensive application including VoIP, high-definition streaming, or online gaming, without the lag. Using its powerful technologies, the router is also able to mitigate data loss over long distances and through obstacles turning your home and even your yard into one big hot spot.
  • Connection encryption
    High encryption standards ensure your wireless connection is safe from intruders.
  • WPS button
    Instantly setup Wi-Fi connections simply by pressing the WPS button.
  • Easy setup
    Use the optimized setup wizard to get online quickly and easily.
TP-Link TL-WR940N - wireless router - Wi-Fi - desktop
Wireless router - 4-port switch (integrated)
Enclosure Type
Desktop
WAN Ports Qty
1
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Network / Transport Protocol
TCP/IP, ICMP/IP, PPPoE
Routing Protocol
Static IP routing
Firewall protection, DMZ port, DHCP support, NAT support, auto-negotiation, auto-uplink (auto MDI/MDI-X), dynamic DNS server, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, SNTP support, MIMO technology, virtual server support
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
20 cm x 14 cm x 2.8 cm
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Data Transfer Rate
300 Mbps
Routing Protocol
Static IP routing
Encryption Algorithm
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
Authentication Method
Radio Service Set ID (SSID)
IEEE 802.3, IEEE 802.3u, IEEE 802.1p, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, FCC
Status Indicators
Port status, power
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM
LAN: 4 x 10Base-T/100Base-TX - RJ-45 , WAN: 1 x 10Base-T/100Base-TX - RJ-45
Aerial
Aerial
External integrated
Antenna Qty
3
Directivity
Omni-directional
Gain Level
3 dBi
External power adapter
20 cm
14 cm
2.8 cm
10 - 90%
BJ7F C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.68
BJ7F C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.87
