The TL-WR710N is designed as an ideal solution to weak Wi-Fi or wired only connection at your home or in a hotel room. With the router plugged in, a secure Wi-Fi hotspot for all your Wi-Fi enabled devices is instantly established. Featuring 5 operating modes, the device allows you to conveniently connect to the internet in different scenarios. Besides, with built-in power adapter, flexible USB port for storage and charging, this compact device is the perfect choice for travelers, students, or anyone else to work or play.
Portable and Compact--Ideal for Home and Travel Use
TL-WR710N is small enough to put into your pocket and take on the road to share the Internet. When your hotel only offers a wired network connection, just plug the network cable into the TL-WR710N and enter the default password to enjoy the convenience of wireless networking in your hotel room.
Multiple Operating Modes for Different Scenarios
Wireless Router Mode (Default)
Creates an instant private wireless network and share Internet to multiple Wi-Fi devices, which is suitable for most hotel and home network.
Client Mode (TV/Game Console)
Gives wired-only devices access to an existing Wi-Fi networks.
Repeater Mode
Extend existing Wi-Fi, improving signal strength and maximizing coverage.
Access Point Mode
Creates a wireless network for Wi-Fi devices.
WISP Client Router Mode
Simultaneous Wireless ISP access and sharing.
Multifunctional USB Port for File Sharing and Charging
Equipped with a multifunctional USB 2.0 port, you can share files and media within local network among your different devices such as PCs, smart phones and tablets. Also, the USB port can provide power supply (up to 5V/1A) to mobile devices like smart phones or tablets, so that you can avoid the trouble of carrying several chargers while travelling.
Advanced Security
TL-WR710N provides WPA/WPA2 encryptions, which effectively and efficiently protect the wireless network.
Portable and compact - ideal for home and travel use
TL-WR710N is small enough to put into your pocket and take on the road to share the Internet. When your hotel only offers a wired network connection, just plug the network cable into the TL-WR710N and enter the default password to enjoy the convenience of wireless networking in your hotel room. -
Multifunctional USB port for file sharing and charging
Equipped with a multifunctional USB 2.0 port, you can share files and media within local network among your different devices such as PCs, smart phones and tablets. Also, the USB port can provide power supply to mobile devices like smart phones or tablets, so that you can avoid the trouble of carrying several chargers while traveling. -
Advanced security
- TP-Link TL-WR710N - wireless router - Wi-Fi - wall-pluggable
- Wireless router
- Enclosure Type
- Wall-pluggable
- WAN Ports Qty
- 1
- Data Link Protocol
- Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Data Transfer Rate
- 150 Mbps
- PPTP, L2TP, IPSec, PPPoE, DHCP
- Routing Protocol
- Static IP routing
- Firewall protection, DMZ port, DHCP support, repeating mode, SPI, DoS attack prevention, MAC address filtering, VPN passthrough, URL filtering, IP address filtering, Access Point operational mode, WMM support, ACL support, virtual server support, wireless bridge mode, Wireless Client Mode, port triggering
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP
- 8.5 cm x 7.5 cm x 2.8 cm
- System Requirements
- Apple MacOS, Linux, Microsoft Windows 2000, Microsoft Windows Vista / XP / 7 / 8
- Wireless router
- Enclosure Type
- Wall-pluggable
- Connectivity Technology
- Wireless, wired
- Frequency Band
- 2.4 GHz
- 150 Mbps
- Routing Protocol
- Static IP routing
- Encryption Algorithm
- 128-bit WEP, 64-bit WEP, 152-bit WEP, WPA, WPA2, WPA-PSK, WPA2-PSK
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n, UPnP, FCC, RoHS
- WAN / LAN: 1 x 10Base-T/100Base-TX - RJ-45 , LAN: 1 x 10Base-T/100Base-TX - RJ-45 , USB 2.0: 1 x 4 pin USB Type A
Aerial
- Aerial
- Internal
- Antenna Qty
- 1
- Power Device
- Internal power supply
- Cables Included
- 1 x network cable
- OS Required
- 8.5 cm
- 7.5 cm
- 2.8 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
C2G 5m USB 2.0 A/B Cable - Black | In Stock | £5.74 |
C2G 12m USB 2.0 A/A Active Extension Cable | In Stock | £18.89 |
