TP LINK TL-WR1043ND N Wireless, Gigabit Router with USB
ALL GIGABIT PORTS, USB SHARING AND ONE BUTTON WPS SETUP!
Quicklinx: 7725WS00 Mfr#: TL-WR1043ND
  • IEEE 802.11n
What Laptop Magazine Award Winner
Windows official Magazine Award Winner
300Mbps Ultimate Wireless N Gigabit Router TL-WR1043ND is a combined wired/wireless network connection device integrated with internet-sharing router and 4-port switch.
It creates wireless network with incredibly high speeds of up to 300Mbps, which ensures that you are free to simultaneously enjoy multiple high-bandwidth consuming and interruption sensitive applications such as streaming HD video, making VoIP calls, sharing large files and playing online games.
Specially, it is equipped with a USB storage port on the back of the router for connecting USB storage devices to the network, for convenient resource sharing for everyone on the network.
Gigabit Ports - Incredible Bandwidth
With built-in Gigabit Ethernet Switch, TL-WR1043ND provides more powerful data processing abilities, which unleashes the full potential of the N-abled freedom, eliminating bottlenecks in transferring speed between megabit wired and 11n wireless connection.
Meanwhile, everything they do will be faster and more efficient, thus users are sharing large files such as high definition video in minutes instead of hours.
Wireless N - Extreme Speed & Range
Complies with the IEEE 802.11n standard, users can create a wireless network and get up to 18X the speed and 6X the range of conventional 11g products.
The router has the speed to work smoothly with almost any bandwidth intensive application including VoIP, HD streaming, or online gaming, without the lag.
Using its powerful N technologies, the router is also able to mitigate data loss over long distances and through obstacles turning your home and even your yard into one big hot - spot.
More Stable Wireless Signals
Signal Sustain Technology (SST) dramatically increases link robustness and throughput by simultaneously transmitting across three spatially-diverse signal paths, and incorporating information from three receivers simultaneously within the signal processing at the receiver.
Network connection drops greatly reduced, link robustness and throughput increased, achieves, on average, 50 percent greater sustained throughput at range than 2x2 MIMO systems.
Clear Channel Assessment (CCA) applies the existing WLAN listen-before-talk rule to the bandwidth needed for binding channels.
It automatically avoids channel conflicts using its clear channel selection feature and fully realizes the advantages of channel binding, greatly enhanced the wireless performance.
USB Storage Port - Portable Server
Centralizing an external storage device and file sharing is easy.
The TL-WR1043ND features a USB port that allows users to attach USB storage such as a flash disk directly to the router itself allowing any network connected users to instantly access the data on the disk such as enjoying HD video directly or sharing flies at will, just like a NAS (Network Attached Storage) system.
Quick Secure Setup
Compatible with Wi-Fi Protected Setup™ (WPS), TL-WR1043ND features Quick Security Setup that allows users to almost instantly setup their security simply by pressing the "QSS" button on the router automatically establishing a WPA2 secure connection, which is more security compared with WEP encryptions.
Not only is this faster than normal security setups but more convenient in that you don't need to remember a password!
IP QoS - Control Bandwidth Reasonably
Among the wireless network, indiscriminate Internet surfing and bandwidth-guzzling downloads by internal users often leave home or small office with insufficient bandwidth.
TL-WR1043ND supports IP QoS function, allowing optimum utilization of bandwidth and offers bandwidth control over congestion, preventing the bandwidth abuse.
In this way, the users of a small network receive committed and specific bandwidth, preventing non-critical applications from degrading network performance.
Easy To Use
Even novice users can easily setup their networking products.
The device comes with a CD with an Easy Setup Assistant that leads you through the setup process step-by-step, and even helps with wireless network settings and security configurations.
  • Extremely high wireless speed
    With high wireless speeds, you can enjoy HD video streaming and online gaming with an even more fluid experience.
  • Fully extended coverage
    3 external 5 dBi antennas combined with higher quality antenna technology provide users with larger wireless coverage and stronger wireless signal intensity from anywhere in your large home or office.
  • Blazing wired speeds
    With 5 built-in Gigabit ports and a hardware NAT function, the wireless router provides powerful data processing capabilities.
Header / Manufacturer
TP-LINK
Header / Model
TL-WR1043ND Ultimate 300Mbps Wireless N Gigabit Router
Wireless router
TP-LINK TL-WR1043ND Ultimate 300Mbps Wireless N Gigabit Router - wireless router - 802.11b/g/n (draft 2.0) - desktop
Wireless router - 4-port switch (integrated)
Connection Type
DSL (Cable)
Networking / Connectivity Technology
Wireless
Enclosure Type
Desktop
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n (draft 2.0)
Networking / Compliant Standards
Frequency Band
2.4 GHz
Speed
300 Mbps
Network / Transport Protocol
TCP/IP, PPTP, L2TP, ICMP/IP, IPSec, PPPoE
Routing Protocol
Static IP routing
Remote Management Protocol
HTTP
Firewall protection, DMZ port, NAT support, auto-negotiation, ARP support, auto-uplink (auto MDI/MDI-X), Stateful Packet Inspection (SPI), DoS attack prevention, dynamic DNS server, auto-fallback, MAC address filtering, VPN passthrough, Wireless Distribution System (WDS) support, URL filtering, parental control, IP address filtering, firmware upgradable, SNTP support, MIMO technology, virtual server support, DHCP server
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, USB 2.0, IEEE 802.11n (draft 2.0), UPnP
Header / Packaged Quantity
1
Networking / WAN Ports Qty
1
Miscellaneous / Encryption Algorithm
128-bit WEP, 152-bit WEP, 64-bit WEP, AES, TKIP, WPA, WPA-PSK, WPA2, WPA2-PSK
Networking / Frequency Band
2.4 GHz
Aerial / Antenna Qty
3
Aerial / Gain Level
3 dBi
Networking / Ports Qty
4
Networking / Integrated Switch
4-port switch
Networking / Wireless Protocol
Networking / Form Factor
Desktop
Networking / Switching Protocol
Ethernet
Standards
Rackmount or External
External
Aerial / Aerial Form Factor (F)
External detachable
Networking / Remote Management Protocol
HTTP
Networking / Network / Transport Protocol
ICMP/IP, IPSec, L2TP, PPPoE, PPTP, TCP/IP
Aerial / Directivity
Omni-directional
Header / Compatibility
PC
Networking / Routing Protocol
Static IP routing
Dimensions & Weight / Height
2.8 cm
Dimensions & Weight / Width
20 cm
Dimensions & Weight / Depth
14 cm
20 cm x 14 cm x 2.8 cm
Environmental Parameters / Min Operating Temperature
Environmental Parameters / Max Operating Temperature
Miscellaneous / Compliant Standards
RoHS
Enclosure Type
Desktop
Wireless, wired
Frequency Band
2.4 GHz
Routing Protocol
Static IP routing
HTTP
AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, USB 2.0, IEEE 802.11n (draft 2.0), UPnP , FCC Class B certified, FCC Part 15
Status Indicators
Link activity, power, link OK, system, status
Line Properties
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM
LAN : 4 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , WAN : 1 x 10Base-T/100Base-TX/1000Base-T - RJ-45 , USB 2.0 : 1 x 4 PIN USB Type A
Aerial
Aerial
External detachable
Antenna Qty
3
Directivity
Omni-directional
Gain Level
3 dBi
External power adapter
Software Included
Drivers & Utilities
20 cm
14 cm
2.8 cm
10 - 90%
7725 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.02
