TP LINK TL-WPA8630P KIT Bridge 3-port switch HomePlug AV
Quicklinx: DHNKWS00 Mfr#: TL-WPA8630P
  • IEEE 802.11n
Expand your Wi-Fi network using your home's existing powerlines. Plug in the TL-WPA8630P to transmit an Internet connection to any area in your home and share that connection with all of your favorite wired and wireless devices. A unified network keeps your connection stable, even as you move around the house.
  • Expansive coverage
    2x2 MIMO with beamforming technology offers the benefit of improved coverage throughout the home, particularly for previously hard to reach outlets.
  • Unified Wi-Fi network
    Wi-Fi auto-sync creates a simple, intuitive powerline experience. Pressing the Wi-Fi clone button instantly copies your network name and password from your router for easy setup. Wi-Fi move automatically applies any settings changes across the network.
TP-Link TL-WPA8630P AV1300 Gigabit Passthrough Powerline ac Wi-Fi Extender - powerline adapter - Wi-Fi 5 - wall-pluggable
Powerline adapter
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, Gigabit Ethernet, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV (HPAV) 2.0, IEEE 1901, IEEE 802.11ac
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1300 Mbps
Routing Protocol
IGMPv2, IGMP, IGMPv3
Parental control, MIMO technology, reset button, Wi-Fi Move technology, Wi-Fi Clone button
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV 2.0, IEEE 1901, IEEE 802.11ac
7.5 cm x 4.2 cm x 15.2 cm
Apple MacOS, Linux, Microsoft Windows XP, Microsoft Windows 7, Microsoft Windows Vista, Windows 8, Windows 8.1, Windows 10
Powerline adapter
Enclosure Type
Wall-pluggable
Wireless, wired
Frequency Band
2.4 GHz / 5 GHz
Data Transfer Rate
1300 Mbps
Max Range Indoors
300 m
Routing Protocol
Encryption Algorithm
WPA-PSK, 128-bit AES, WPA2-PSK, WEP
Authentication Method
Radio Service Set ID (SSID)
Wi-Fi Rating
AC1350
IEEE 802.3, IEEE 802.3u, IEEE 802.3ab, IEEE 802.11b, IEEE 802.11a, IEEE 802.11g, IEEE 802.11n, HomePlug AV 2.0, IEEE 1901, IEEE 802.11ac, RoHS
Status Indicators
Power, LAN, powerline, Wi-Fi
Line Properties
Line Coding Format
OFDM
LAN: 3 x Ethernet 1000
Internal power supply
11 Watt
Network cable
7.5 cm
4.2 cm
15.2 cm
10 - 90% (non-condensing)
