TP LINK TL-WA860RE 300Mbps WiFi Range Extender with AC Passthrough
Quicklinx: 9T94WS00 Mfr#: TL-WA860RE
Type: Wi-Fi range extender
Connectivity: Wired, Wireless
Speed: 300Mbps
Protocol: IEEE 802.11g, IEEE 802.11b, IEEE 802.11n, Fast Ethernet + 1 more
Compatibility: Mac, PC
  • IEEE 802.11n
14 In Stock
£18.92 ex VAT
£22.70 inc VAT
TP-LINK's TL-WA860RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones". With 300Mbps wireless N speeds, Range Extender button, miniature size and wall mounting design, extending a wireless network has never been easier. In addition, its extra outlet makes power available for other electrical devices. What's more, its Ethernet port allows the TL-WA860RE to act as a wireless adapter to turn a wired device into a wireless one.
300Mbps Range Extender
The TL-WA860RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones", help users maintain an existing wireless network and vastly improve the network's coverage. With 300Mbps wireless 802.11n speeds, it is ideal for smooth HD video, music streaming and online gaming.
Flexible Deployment
The device's miniature size and wall-mounted design make it easy to deploy and move flexibly. What's more, the TL-WA860RE's profile function remembers previously paired wireless networks, meaning there is no need to reset the device when changing the paired router.
Extra Power Socket for Additional Devices
With its integrated power socket, the new TL-WA860RE provides real convenience for your home network. The integrated power socket allows an additional device or power bar to be connected to the Range Extender as though it were a normal wall socket. This ensures that even with the TL-WA860RE plugged in, no power outlet is going to waste.
Plug and Play
With no new wires or cables, within range of their existing wireless network, users can easily extend wireless coverage at a push of the WPS button on their router followed by the Range Extender button on the TL-WA860RE or vice versa.
Superior Range
With 2 fixed external antennas combined with higher quality antenna technology, you can experience excellent WiFi coverage and reliability no matter where you connect in your home.
Ethernet Bridge
The TL-WA860RE's single Ethernet port allows the Extender to function as a wireless adapter to connect wired devices like Blu-ray® players, gaming consoles, DVRs and Internet TVs. At the same time, the device can share the wireless network as well.
Smart Signal Indicator Light
Intelligent signal light can help to find the best location to place the range extender so that the TL-WA860RE can achieve the best possible range and performance of the network.
Universal Compatibility
It works seamlessly with all 802.11 b/g/n wireless devices.
  • 300 Mbps range extender
    The TL-WA860RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones", help users maintain an existing wireless network and vastly improve the network's coverage. With 300 Mbps wireless 802.11n speeds, it is ideal for smooth HD video, music streaming and online gaming.
  • Flexible deployment
  • Extra power socket for additional devices
    With its integrated power socket, the TL-WA860RE provides real convenience for your home network. The integrated power socket allows an additional device or power bar to be connected to the range extender as though it were a normal wall socket. This ensures that even with the TL-WA860RE plugged in, no power outlet is going to waste.
  • Plug and Play
    With no new wires or cables, within range of their existing wireless network, users can easily extend wireless coverage at a push of the WPS button on their router followed by the range extender button on the TL-WA860RE or vice versa.
  • Superior range
    With 2 detachable external antennas combined with higher quality antenna technology, you can experience excellent Wi-Fi coverage and reliability no matter where you connect in your home.
  • Ethernet bridge
    The TL-WA860RE's single Ethernet port allows the extender to function as a wireless adapter to connect wired devices like Blu-ray players, gaming consoles, DVRs and Internet TVs. At the same time, the device can share the wireless network as well.
  • Smart signal indicator light
  • Universal compatibility
TP-Link TL-WA860RE - Wi-Fi range extender - Wi-Fi
External
Ethernet, Fast Ethernet, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Frequency Band
2.4 GHz
UNIX, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Windows 8, Microsoft Windows 2000/XP/Vista/7/8
11 cm x 6.58 cm x 7.52 cm
3-year warranty
11 cm
6.58 cm
7.52 cm
External
Wireless, wired
Data Transfer Rate
300 Mbps
Frequency Band
2.4 GHz
MAC address filtering, Wi-Fi Multimedia (WMM) support
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA-PSK, WPA2-PSK
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Aerial
Antenna
External detachable
Antenna Qty
2
1 x 100Base-TX - RJ-45
1 x network cable
Plug and Play, RoHS
3 Watt
Software Included
Drivers & Utilities
Limited warranty - 3 years
10 - 90% (non-condensing)
9T94 C2G 5m Cat6 550 MHz Snagless Patch Cable - Grey In Stock £8.56
9T94 C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £10.65
Connectivity: Wired
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11b
Protocol: IEEE 802.11n
Protocol: Fast Ethernet
Protocol: Ethernet
Compatibility: Mac
Compatibility: PC
Antennas: 2
Brand: TP LINK
