TP LINK TL-WA854RE 300Mbps Universal WiFi Range Extender
Quicklinx: 9L10WS00 Mfr#: TL-WA854RE
Type: Wi-Fi range extender
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: Mac, PC
  • IEEE 802.11n
£11.59 ex VAT
£13.90 inc VAT
TP-LINK's TL-WA854RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones". With 300Mbps wireless N speeds, Range Extender button, miniature size and wall mounting design, extending a wireless network has never been easier.
The TL-WA854RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones", help users maintain an existing wireless network and vastly improve the network's coverage. With 300Mbps wireless 802.11n speeds, it is ideal for smooth HD video, music streaming and online gaming.
Flexible Deployment
The device's miniature size and wall-mounted design make it easy to deploy and move flexibly. What's more, the TL-WA854RE's profile function remembers previously paired wireless networks, meaning there is no need to reset the device when changing the paired router.
Plug and Play
With no new wires or cables, within range of their existing wireless network, users can easily extend wireless coverage at a push of the WPS button on their router followed by the Range Extender button on the TL-WA854RE or vice versa. An additional push of the pair button can quickly establish an encrypted connection with client devices.
Smart Signal Indicator Light
5 signal lights represent the current signal strength that TL-WA854RE receives from existing router, which can help to find the right location to place the range extender so that the TL-WA854RE can achieve the best possible range and performance of the network.
Universal Compatibility
Works seamlessly with all 802.11 n/g/b wireless devices. It is also compatible with the latest Windows 8 operating system.
  • 300 Mbps range extender
    The TL-WA854RE is designed to conveniently extend the coverage and improve the signal strength of an existing wireless network to eliminate "dead zones", help users maintain an existing wireless network and vastly improve the network's coverage. With 300 Mbps wireless 802.11n speeds, it is ideal for smooth HD video, music streaming and online gaming.
  • Flexible deployment
  • Plug and Play
  • Smart signal indicator light
TP-Link TL-WA854RE 300Mbps Universal WiFi Range Extender - Wi-Fi range extender
External
Frequency Band
2.4 GHz
UNIX, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows NT, Microsoft Windows 2000/XP/Vista/7/8
6.58 cm x 7.52 cm x 11 cm
3-year warranty
6.58 cm
7.52 cm
11 cm
External
Wireless
Data Transfer Rate
300 Mbps
Line Coding Format
DBPSK, DQPSK, CCK, 64 QAM, 16 QAM, OFDM
Spread Spectrum Method
DSSS
Network / Transport Protocol
TCP/IP, DHCP
Frequency Band
2.4 GHz
Status Indicators
Power, wireless
Auto-negotiation, MAC address filtering, firmware upgradable, Wi-Fi Multimedia (WMM) support, Wi-Fi Protected Setup (WPS)
Encryption Algorithm
128-bit WEP, 64-bit WEP, 152-bit WEP, WPA-PSK, WPA2-PSK
Aerial
Antenna Qty
2
Plug and Play, RoHS
3 Watt
Software Included
Drivers & Utilities
Limited warranty - 3 years
10 - 90% (non-condensing)
Speed: 300Mbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: Mac
Compatibility: PC
Brand: TP LINK
Price Range Ex VAT: 0 - 50
