TP LINK TL-WA801N N300 Wi-Fi Access Point
Quicklinx: FT85WS00 Mfr#: TL-WA801N
Type: Radio access point
Connectivity: Wireless
Speed: 300Mbps
Protocol: IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
Compatibility: PC
  • IEEE 802.11n
41 In Stock
£19.68 ex VAT
£23.61 inc VAT
The TP-LINK Wireless N Access Point TL-WA801N is designed to establish or expand a scalable high-speed wireless N network or to connect multiple Ethernet-enabled devices such as game consoles, digital media adapters, printers, or network-attached storage devices to a wireless network. The AP supports a host of different functions that makes your wireless networking experience more flexible than ever before. Now, you can enjoy a better Internet experience when downloading, gaming, video streaming or any other applications that you may wish to use.
  • Wireless N - speed & range
    Adopting IEEE 802.11n advanced MIMO (Multi Input Multi Output) technology, it simultaneously works through two antennas to Tx and Rx to overcome the interference and signal degradation when traveling long distances or through physical barriers in a small office or a large apartment, resulting in an incredible improvement in the wireless performance, even in a steel-and-concrete building. Above all, you could easily pick up the wireless network during long-distance connection where legacy 11g products may not!
  • Multiple operating modes - easy to build WLAN
    Supports multiple operation modes (Access Point, Multi-SSID, Client, Range Extender) to enable various wireless applications to give users a more dynamic and comprehensive experience when using their APs. Multiple operating modes also help you easily build wireless network for hard-to-wire locations or eliminating wireless dead zone.
  • Passive PoE supported - more flexible deployment
    The TL-WA801N is able to be powered using an Ethernet cable to simultaneously send data and electricity to wherever your AP may be located even up to 100 feet away. This feature multiplies your options allowing you to place the AP in a position that is most convenient to get the best signal possible, such as on the wall or on the ceiling of your office.
TP-Link TL-WA801N - radio access point - Wi-Fi
Radio access point
External
Frequency Band
2.4 GHz
PoE injector
UNIX, Apple MacOS, Novell NetWare, Microsoft Windows 98 Second Edition, Linux, Microsoft Windows 2000, Microsoft Windows NT, Microsoft Windows XP, Microsoft Windows Vista, Microsoft Windows 7 / 8 / 8.1 / 10
Power Over Ethernet (PoE) Supported
PoE
18.16 cm x 12.95 cm x 3.62 cm
Radio access point
18.16 cm
12.95 cm
3.62 cm
External
Wireless
Data Transfer Rate
300 Mbps
Remote Management Protocol
SNMP
Frequency Band
2.4 GHz
Repeating mode, MIMO technology, Wi-Fi Multimedia (WMM) support, Multiple SSID support, reset button, WPS button
Encryption Algorithm
WPA, WPA2, WPA-PSK, WPA2-PSK, WEP
Aerial
Antenna
External integrated
Antenna Qty
2
Directivity
Omni-directional
1 x 100Base-TX - RJ-45
PoE injector
FCC, RoHS
PoE
External power adapter
10 - 90% (non-condensing)
Speed: 300Mbps
Protocol: IEEE 802.11g
Protocol: IEEE 802.11n
Compatibility: PC
Antennas: 2
Brand: TP LINK
