TP-LINK High Power Wireless Access Point TL-WA7210N is dedicated to WISP CPE solutions and long distance wireless network solutions. It features up to 500mw wireless transmission power and has a built-in 12dBi dual-polarized antenna which provides an efficient way to pick up and maintains a stable signal for a wireless network connection ranging multiple kilometers.
High Transmission Capability
With up to 500mw wireless transmission power and a 12dBi dual-polarized high gain antenna, the TL-WA7210N can produce and pick up a powerful and stable signal for a wireless connection ranging multiple kilometers.
Professional Outdoor Design
TL-WA7210N features a weatherproof enclosure and special protection against ESD and lightning. It supports passive Power over Ethernet (PoE), making it a versatile outdoor networking solution.
Multiple Applications
TL-WA7210N is dedicated to WISP CPE solutions and long distance wireless network solutions especially for WISP services, The AP will behave as a client of the Wireless Internet Service Provider (WISP). Two TL-WA7210Ns can create a point to point link for a long-distance wireless connection. What's more, the TL-WA7210N can create point to multi-point links for wireless coverage servicing multiple locations.
Intelligent Management Tools
Tool 1: Antenna Alignment
Users can use the antenna alignment tool to adjust the direction of their APs using a live signal strength meter to judge which direction is best making setup that much simpler.
Tool 2: Distance Setting
With the AP's ACK timeout tool able to adjust the distance between two APs, it allows users to set a specific distance in order to establish the most robust wireless connection possible.
Tool 3: Ping Watch Dog
Ping Watch Dog enables users to maintain the ping command to check the quality of the wireless link and can reboot the remote AP if the wireless signal becomes worse or disconnects.
High transmission capability
With up to 500mw wireless transmission power and a 12 dBi dual-polarized high gain antenna, the TL-WA7210N can produce and pick up a powerful and stable signal for a wireless connection ranging multiple kilometers. -
Professional outdoor design
TL-WA7210N features a weatherproof enclosure and special protection against ESD and lightning. It supports passive Power over Ethernet (PoE), making it a versatile outdoor networking solution. -
Multiple applications
- TP-Link TL-WA7210N 150Mbps Outdoor Wireless Access Point - radio access point - Wi-Fi
- Radio access point
- Form Factor
- External
- Data Link Protocol
- IEEE 802.11b, IEEE 802.11g, IEEE 802.11n
- Frequency Band
- 2.4 GHz
- Included Accessories
- PoE injector, pole mount
- OS Required
- UNIX, Apple MacOS, Novell NetWare, Linux, Microsoft Windows NT, Microsoft Windows 98 Second Edition / Windows 2000, Microsoft Windows Vista / XP / 7 / 8
- Power Over Ethernet (PoE) Supported
- PoE
- 26.5 cm x 12 cm x 8.3 cm
- 26.5 cm
- 12 cm
- 8.3 cm
- Form Factor
- External
- Connectivity Technology
- Wireless
- Data Transfer Rate
- 150 Mbps
- Frequency Band
- 2.4 GHz
- Status Indicators
- Signal strength
- Auto-sensing per device, auto-uplink (auto MDI/MDI-X), repeating mode, MAC address filtering, Wireless Distribution System (WDS) support, Access Point operational mode, WISP mode, wireless bridge mode, Wireless Client Mode, weatherproof, Low Noise Amplifier (LNA)
- Encryption Algorithm
- AES, 128-bit WEP, 64-bit WEP, 152-bit WEP, TKIP, WPA, WPA2, WPA-PSK, WPA2-PSK
- Authentication Method
- Radio Service Set ID (SSID)
Aerial
- Antenna Qty
- 1
- Directivity
- Directional
- Gain Level
- 12 dBi
- 1 x 100Base-TX - RJ-45 , 1 x aerial
- FCC, RoHS
- PoE
- Power Device
- External power adapter
- OS Required
- -30 °C
- 70 °C
- 10 - 90% (non-condensing)
C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue | In Stock | £4.91 |
