TP LINK TL-SL1226P 24-Port 10/100 Mbps + 2-Port Gigabit Rack Switch
Quicklinx: FT8RWS00 Mfr#: TL-SL1226P
Type: Fast Ethernet
Ports: 26
Data Transfer Rate: 8.5Gbps
Managed: No
POE: PoE+
18 In Stock
£150.28 ex VAT
£180.33 inc VAT
TP-Link's new PoE/PoE+ switches with all 10/100 Mbps RJ45 ports supporting the PoE+ standard provides a simple way to expand the wired network while transferring power over the same Ethernet cable at the same time. With up to 30 W per port TL-SL1226P can power more high-powered devices such as Access Points, IP Cameras, IP Phones and so on. Moreover, with innovative Extend Mode, devices can get PoE power supply and data transmission from a distance of 250 m. Priority mode ensures high priority for port 1 - 8, which guarantees the quality of sensitive applications. TL-SL1226P supports Isolation Mode that divides traffic for ports 1 - 24 for higher security and performance.
TP-Link TL-SL1226P - switch - 26 ports - unmanaged - rack-mountable
Switch - 26 ports - unmanaged
Enclosure Type
Rack-mountable 1U
Subtype
Fast Ethernet
Ports
24 x 10/100 (PoE+) + 2 x 10/100/1000 + 2 x combo Gigabit SFP
Power Over Ethernet (PoE)
PoE+
PoE Budget
250 W
Performance
Switching capacity: 8.8 Gbps , Packet forwarding rate: 6.54 Mpps
Packet buffer size: 4.1 Mbit
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Flow control, PoE, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, PoE+, 2 fans, MAC address learning, MAC address aging, priority mode, extend mode, security slot (Kensington security lock compatible)
IEEE 802.3u, IEEE 802.3i, IEEE 802.3z, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
44 cm x 18 cm x 4.4 cm
Enclosure Type
Desktop, rack-mountable 1U
Subtype
Fast Ethernet
Ports
PoE+
PoE Budget
250 W
Performance
8K entries
Jumbo Frame Support
10KB
Status Indicators
Power, 100M device connected, 1000M device connected, PoE, link/activity, PoE max
24 x 100Base-TX RJ-45 PoE+ - 30 W , 2 x 1000Base-T RJ-45 , 2 x 1000Base-X SFP
Internal power supply
294 Watt
Rack Mounting Kit
Included
Plug and Play, FCC, RoHS
44 cm
18 cm
4.4 cm
50 °C
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Type: Fast Ethernet
Ports: 26
Managed: No
POE: PoE+
Brand: TP LINK
