TP LINK TL-SG116 16-Port Gigabit Desktop Switch
Quicklinx: FCMJWS00 Mfr#: TL-SG116
Type: Gigabit Ethernet
Ports: 16
Data Transfer Rate: [N/A]
Managed: No
POE: No
12 In Stock
£51.79 ex VAT
£62.14 inc VAT
The TP-Link 16-port 10/100/1000Mbps Desktop Switch provides you an easy way to make the transition to Gigabit Ethernet. Increase the speed of your network server and backbone connections, or make Gigabit to the desktop a reality. Plug and Play design, with no configuration required, makes the product easy to use. Moreover, TL-SG116 adopts lower power consumption design. With the innovative energy-efficient technology, the TL-SG116 can save power consumption, making it an eco-friendly solution for your home or office network.
  • Gigabit switch
    Featured with 16 10/100/1000Mbps ports, TL-SG116 greatly expands your network capacity, enabling instant large files transferring. So, power users in the home, office, workgroup, or creative production environment can now move large, bandwidth-intensive files faster. Transfer graphics, CGI, CAD, or multimedia files across the network instantly.
  • Go green with your Ethernet
    You now have the choice to go green when upgrading to a gigabit network! This new generation TL-SG116 16-Port 10/100/1000Mbps Desktop Switch features the latest innovative energy-efficient technologies that can greatly expand your network capacity with much less power. It automatically adjusts power consumption according to the link status and cable length to limit the carbon footprint of your network.
  • Traffic optimization
    802.1p and DSCP QoS enable smooth latency-sensitive traffic such as voice and video, and IGMP Snooping optimizes the Multicast data stream.
  • Easy to use
    The auto features of this gigabit switch make installation plug and play and hassle-free. No configuring is required. Auto MDI/MDIX eliminates the need for crossover cables. Auto-negotiation on each port senses the link speed of a network device (either 10, 100, or 1000 Mbps) and intelligently adjusts for compatibility and optimal performance. Moreover, fanless design ensures quiet operation.
TP-Link TL-SG116 - switch - 16 ports
Switch - 16 ports
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
Packet forwarding rate: 23.8 Mpps
MAC Address Table Size
8K entries
Jumbo Frame Support
10KB
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), IGMP snooping, store and forward, fanless
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.1p, IEEE 802.3x
28.6 cm x 11.17 cm x 2.54 cm
Switch - 16 ports
Enclosure Type
Desktop
Subtype
Gigabit Ethernet
Ports
16 x 10/100/1000
Performance
8K entries
Jumbo Frame Support
10KB
16 x 1000Base-T RJ-45
External power adapter
10 Watt
Rubber feet
FCC, RoHS
28.6 cm
11.17 cm
2.54 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Ports: 16
Managed: No
POE: No
Brand: TP LINK
