TL-SF1009P is an unmanaged switch with 9 10/100Mbps ports that requires no configuration and provides 8 PoE (Power over Ethernet) ports. It can automatically detect and supply power with all IEEE 802.3af/at compliant Powered Devices (PDs). In this situation, the electrical power is transmitted along with data in one single cable allowing you to expand your network to where there are no power lines or outlets, where you wish to fix devices such as APs, IP Cameras or IP Phones, etc.
Power Over Ethernet
8 of the 9 Auto-Negotiation RJ45 ports (port 1 to port 8) of the switch support Power over Ethernet (PoE) function. These PoE ports can automatically detect and supply power with those IEEE 802.3af/at compliant Powered Devices (PDs). -
Overload arrangement
TL-SF1009P has the priority function which will help protect the system when the system power is overloaded. -
Intelligent power management
Priority (port 1 = port 2 = port 3 > port 4): this function will help protect the system when the system power is overloaded. For example, port 1, 2 and 4 is using 20 W (maximum power per port is 30 W); the system power is 60 W in total. If there is an additional PD inserted to port 3 with 20 W, and then the system will cut off the power of port 4 because of the overloaded power, this means port 1, 2, and 3 will use 20 W, no power will be supplied to port 4. -
Easy to use
TL-SF1009P is easy to install and use. It requires no configuration and installation. With desktop and wall mountable design, outstanding performance and quality, the TP-Link 9-Port 10/100Mbps Desktop Switch with 8-Port PoE+ TL-SF1009P is a great selection for expanding your network.
- TP-Link TL-SF1009P - switch - 9 ports - unmanaged
- Switch - 9 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100 (PoE+) + 1 x 10/100
- Power Over Ethernet (PoE)
- PoE+
- PoE Budget
- 65 W
- Performance
- Bandwidth: 1.8 Gbps
- MAC Address Table Size
- 2K entries
- Flow control, full duplex capability, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, fanless, security lock slot (cable lock sold separately)
- IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
- 17.1 cm x 9.8 cm x 2.7 cm
- Enclosure Type
- Desktop
- Subtype
- Fast Ethernet
- Ports
- PoE+
- PoE Budget
- 65 W
- Performance
- 2K entries
- Status Indicators
- Power, link/activity, uplink, PoE max
- 8 x 100Base-TX RJ-45 PoE+ , 1 x 100Base-TX RJ-45 uplink
- Power Device
- External power adapter
- Installed Qty
- 1
- Power Provided
- 53.5 V
- 77.08 Watt
- Plug and Play, FCC, RoHS, ANSI/TIA/EIA 568
- 17.1 cm
- 9.8 cm
- 2.7 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
