The TL-SF1008LP is a professional switch with 4 PoE ports. Quality of sensitive applications like video monitoring in critical business areas is guaranteed by offering higher priority options for ports 1-2 when one-touch priority ode is on. It is fully compatible with IP cameras, access points, IP phones, computers, printers, and more.
                Intelligent power managementWhen total power consumption exceeds 41 W, the intelligent power management will cut the lower priority port power. This ensures the high priority port's power supply and protects the device from power overload. It also automatically detects and provides the required power for your PoE devices while protecting your PoE and non-PoE equipment from being damaged.
                Durable metal casingThe interior components of TL-SF1008LP are protected by high-quality metal casing to ensure a long product life. Having passed an array of stringent reliability tests, TL-SF1008LP delivers switching performance you can depend on.
- TP-Link TL-SF1008LP - V1 - switch - 8 ports - unmanaged
- Switch - 8 ports - unmanaged
- Subtype
- Fast Ethernet
- Ports
- 8 x 10/100 (4 PoE)
- Power Over Ethernet (PoE)
- PoE
- PoE Budget
- 41 W
- Performance
- Bandwidth: 1.6 Gbps
- MAC Address Table Size
- 2K entries
- Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, fanless, security lock slot (cable lock sold separately), priority mode, extend mode, Intelligent Power Management
- IEEE 802.3af, IEEE 802.3x
- 17.1 cm x 9.8 cm x 2.7 cm
- Enclosure Type
- Desktop, wall-mountable
- Subtype
- Fast Ethernet
- Ports
- PoE
- PoE Budget
- 41 W
- Performance
- 2K entries
- 8 x 100Base-TX RJ-45 4 ports (PoE) - 15.4 W
- Power Device
- External power adapter
- Power Provided
- 53.5 V - 0.81 A
- 47.1 Watt
- Plug and Play, FCC, RoHS
- 17.1 cm
- 9.8 cm
- 2.7 cm
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- Min Storage Temperature
- -40 °C
- Max Storage Temperature
- 70 °C
- Humidity Range Storage
- 5 - 90% (non-condensing)
