TP LINK TL-SF1006P - V1 Switch - Unmanaged - 6x 10/100 (4 PoE+) - PoE+ (67 W)
Quicklinx: FZ6TWS00 Mfr#: TL-SF1006P
Type: Fast Ethernet
Ports: 6
Data Transfer Rate: [N/A]
Managed: No
POE: PoE+
14 In Stock
£34.69 ex VAT
£41.62 inc VAT
TL-SF1006P is professional high-power switch with 4 PoE+ ports. The total 41 W PoE power budget for the four PoE ports opens up a wide range of applications, such as surveillance for offices, dormitories, and small businesses. It is fully compatible with IP cameras, access points, IP phones, computers, printers, and more. With extend mode, the PoE transmission distance reaches up to 250 m - perfect for IP camera deployment in large areas. The interior components of TL-SF1006P are protected by high-quality metal casing to ensure a long product life.
  • Dedicated 4-port PoE+ switch (67 W budget) for numerous applications
  • Ideal for IP surveillance - up to 250 m transmissions
  • Priority video quality guaranteed
    Quality of sensitive applications like video monitoring in critical business areas is guaranteed by offering higher priority options for ports 1 - 2 when one-touch Priority Mode is on.
  • Intelligent power management
    When total power consumption exceeds 67 W, the intelligent power management will cut the lower priority port power. This ensures the high priority port's power supply and protects the device from power overload. It also automatically detects and provides the required power for your PoE devices while protecting your PoE and non-PoE equipment from being damaged.
  • Durable metal casing
    The interior components of TL-SF1006P are protected by high-quality metal casing to ensure a long product life. Having passed an array of stringent reliability tests, TL-SF1006P delivers switching performance you can depend on.
TP-Link TL-SF1006P - V1 - switch - 6 ports - unmanaged
Switch - 6 ports - unmanaged
Subtype
Fast Ethernet
Ports
6 x 10/100 (4 PoE+)
Power Over Ethernet (PoE)
PoE+
PoE Budget
67 W
Performance
Packet forwarding rate: 0.8928 Mpps , Switching capacity: 1.2 Gbps
MAC Address Table Size
2K entries
Flow control, auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward, half duplex mode, full duplex mode, fanless, security lock slot (cable lock sold separately), priority mode, extend mode, Intelligent Power Management
IEEE 802.3af, IEEE 802.3x, IEEE 802.3at
15.8 cm x 10.1 cm x 2.5 cm
Enclosure Type
Desktop, wall-mountable
Subtype
Fast Ethernet
Ports
6 x 10/100 (4 PoE+)
PoE+
PoE Budget
67 W
Performance
2K entries
6 x 100Base-TX RJ-45 4 ports (PoE+) - 30 W
External power adapter
Power Provided
53.5 V - 1.31 A
74 Watt
Plug and Play, FCC, RoHS
15.8 cm
10.1 cm
2.5 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Type: Fast Ethernet
Ports: 6
Managed: No
POE: PoE+
Brand: TP LINK
