TP LINK TL-SF1005P 5-Port 10/100 Mbps Desktop Switch
Quicklinx: FCMKWS00 Mfr#: TL-SF1005P
Type: Fast Ethernet
Ports: 5
Data Transfer Rate: [N/A]
Managed: No
POE: PoE
21 In Stock
£28.15 ex VAT
£33.78 inc VAT
TL-SF1005P is a 5 10/100Mbps ports unmanaged switch that requires no configuration and provides 4 PoE (Power over Ethernet) ports. It can automatically detect and supply power with all IEEE 802.3af compliant Powered Devices (PDs). In this situation, the electrical power is transmitted along with data in one single cable allowing you to expand your network to where there are no power lines or outlets, where you wish to fix devices such as APs, IP Cameras or IP Phones, etc.
  • Power over Ethernet
    4 of the 5 Auto-Negotiation RJ45 ports (Port 1 to Port 4) of the switch support Power over Ethernet (PoE) function. These PoE ports can automatically detect and supply power with those IEEE 802.3af compliant Powered Devices (PDs).
  • Overload arrangement
    TL-SF1005P has the priority function which will help protect the system when the system power is overloaded. If all PoE PDs power consumption is >= 58W, a priority will be arranged among the PoE ports, then the system will cut off the power of the lowest-priority port.
  • Port priority function
    Priority (port-1=port-2=port-3>port-4): This function will help to ensure the normal operation of the system, it means Port 4 will be cut off when all total PoE PDs power consumption exceed 58W. For an example, Port 1, 2 and 4 is using 15.4W (maximum power for per port is 15.4W); the system power is 46.2W in total. If there is an additional PD inserted to Port 3 with 12W, and then the system will cut off the power of Port 4 because of the overloaded power, this means Port 1, 2 will use 15.4W, and Port3 will use 12W, no power will be supplied to Port 4.
  • Easy to use
    TL-SF1005P is easy to install and use. It requires no configuration and installation. With desktop design, outstanding performance and quality, the TP-Link's TL-SF1005P 5-Port 10/100Mbps Desktop Switch with 4-Port PoE is an ideal choice for expanding your home or office network.
TP-Link TL-SF1005P - switch - 5 ports - unmanaged
Switch - 5 ports - unmanaged
Subtype
Fast Ethernet
Ports
5 x 10/100 (4 PoE)
Power Over Ethernet (PoE)
PoE
PoE Budget
58 W
Performance
Switching capacity: 1 Gbps
MAC Address Table Size
2K entries
Auto-negotiation, auto-uplink (auto MDI/MDI-X), store and forward
IEEE 802.3, IEEE 802.3u, IEEE 802.3af, IEEE 802.3x
9.98 cm x 9.8 cm x 2.5 cm
Enclosure Type
Desktop
Subtype
Fast Ethernet
Ports
5 x 10/100 (4 PoE)
PoE
PoE Budget
58 W
Performance
2K entries
Status Indicators
PoE, link/activity
4 x 100Base-TX RJ-45 PoE - 15.4 W , 1 x 100Base-TX RJ-45
External power adapter
FCC
9.98 cm
9.8 cm
2.5 cm
10 - 90% (non-condensing)
Min Storage Temperature
-40 °C
Max Storage Temperature
70 °C
Humidity Range Storage
5 - 90% (non-condensing)
Type: Fast Ethernet
Ports: 5
Managed: No
POE: PoE
Brand: TP LINK
