The PoE+ injector TL-POE160S fully complies with IEEE 802.3af/at standards, and can work with all IEEE 802.3af/at PoE compliant PDs (powered devices) or PoE receiver adapters, such as TP-Link's TL-POE10R, or other equivalent product, to expand your network to where there are no power line or outlet, where you wish to fix device such as AP, IP camera or IP phone, etc.
Efficient Power Delivery
The PoE splitter provides a maximum output power of 30 W, making it suitable for powering devices without the need for additional power sources. -
Easy Installation
Designed for Plug-and-Play operation, the splitter ensures a hassle-free setup process, allowing users to connect devices quickly. -
Durable Environmental Performance
With a wide operating temperature range of 0°C to 40°C and humidity tolerance of 10-90%, the splitter can perform reliably in varied environments. -
Monitoring Capabilities
The integrated LED indicator provides a visual cue to monitor the operational status of the splitter, enhancing user awareness. -
Versatile Mounting Options
The wall-mountable design allows for strategic placement of the splitter, saving space while ensuring easy accessibility.
- TP-Link TL-POE160S - PoE splitter - 30 Watt
- PoE splitter - external
- Power Over Ethernet (PoE)
- PoE+
- Input Voltage
- AC 100-240 V
- Power Capacity
- 30 Watt
- Input Connectors
- 1 x RJ-45
- 12.5 cm x 5.94 cm x 3.68 cm
- PoE+ (IEEE 802.3at)
- Input Voltage
- AC 100-240 V
- Frequency Required
- 50/60 Hz
- Input Connectors
- 1 x RJ-45
- Power Capacity
- 30 Watt
- 1 x Gigabit LAN - RJ-45
- Wall mountable, LED indicator, Auto-Sensing Technology
- IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3at, Plug and Play, FCC, RoHS
- 0 °C
- 40 °C
- 10 - 90% (non-condensing)
- 12.5 cm
- 5.94 cm
- 3.68 cm
