TP LINK TL-POE160S PoE+ Injector
Quicklinx: G6XGWS00 Mfr#: TL-POE160S
Type: PoE Kit
15 In Stock
£15.96 ex VAT
£19.15 inc VAT
The PoE+ injector TL-POE160S fully complies with IEEE 802.3af/at standards, and can work with all IEEE 802.3af/at PoE compliant PDs (powered devices) or PoE receiver adapters, such as TP-Link's TL-POE10R, or other equivalent product, to expand your network to where there are no power line or outlet, where you wish to fix device such as AP, IP camera or IP phone, etc.
  • Efficient Power Delivery
    The PoE splitter provides a maximum output power of 30 W, making it suitable for powering devices without the need for additional power sources.
  • Easy Installation
    Designed for Plug-and-Play operation, the splitter ensures a hassle-free setup process, allowing users to connect devices quickly.
  • Durable Environmental Performance
    With a wide operating temperature range of 0°C to 40°C and humidity tolerance of 10-90%, the splitter can perform reliably in varied environments.
  • Monitoring Capabilities
    The integrated LED indicator provides a visual cue to monitor the operational status of the splitter, enhancing user awareness.
  • Versatile Mounting Options
    The wall-mountable design allows for strategic placement of the splitter, saving space while ensuring easy accessibility.
TP-Link TL-POE160S - PoE splitter - 30 Watt
PoE splitter - external
Power Over Ethernet (PoE)
PoE+
Input Voltage
AC 100-240 V
Power Capacity
30 Watt
Input Connectors
1 x RJ-45
12.5 cm x 5.94 cm x 3.68 cm
PoE+ (IEEE 802.3at)
Input Voltage
AC 100-240 V
Frequency Required
50/60 Hz
Input Connectors
1 x RJ-45
Power Capacity
30 Watt
1 x Gigabit LAN - RJ-45
Wall mountable, LED indicator, Auto-Sensing Technology
IEEE 802.3u, IEEE 802.3i, IEEE 802.3ab, IEEE 802.3af, IEEE 802.3at, Plug and Play, FCC, RoHS
10 - 90% (non-condensing)
12.5 cm
5.94 cm
3.68 cm
Type: PoE Kit
Brand: TP LINK
