TP LINK TL-PB10400 10400mAh Power Bank
Quicklinx: 9J37WS00 Mfr#: TL-PB10400
Powerful Capacity
Powerful capacity of 10400mAh lets you charge a smartphone 3~5 times, keeping your devices running all the time.
* Actual number of charge times depends on your device's battery size.
Simultaneously Super-fast Charging
Dual USB ports (5V/2A and 5V/1A) allow for charging two devices simultaneously. Built-in special circuit provides full speed for your smartphones.
Reliable Power
TL-PB10400's multiple protections of short circuit, over-voltage, over-current, over-charge, over-discharge, and over-heating ensure safe and reliable charging to avoid any potential harm to your devices.
High Energy Efficiency Rate
Combining high quality circuit, TL-PB10400 greatly reduces unnecessary energy loss while charging, ensuring up to 90% energy efficiency rate. So under full capacity, it can charge a smartphone for 3~5 times, ideal for extended use of mobile devices.
Practical Functions for Convenience
Smart LED Indicator: Four LED lights work as charge indicators to show battery level or charging status
Practical Flashlight: Built-in flashlight comes in handy for in-house and off-road activities
Universal Compatibility
Compatible with almost any smart devices like iPhones, iPads, Android smartphones and other 5V input USB-charged devices.
  • Simultaneously super-fast charging
    Dual USB ports (5 V/2 A and 5 V/1 A) allow for charging two devices simultaneously. Built-in special circuit provides full speed for your smartphones.
  • Reliable power
  • High energy efficiency rate
    Combining high quality circuit, TL-PB10400 greatly reduces unnecessary energy loss while charging, ensuring up to 90% energy efficiency rate. So under full capacity, it can charge a smartphone for 3-5 times, ideal for extended use of mobile devices.
  • Practical functions for convenience
    Smart LED indicator: four LED lights work as charge indicators to show battery level or charging status. Practical flashlight: built-in flashlight comes in handy for in-house and off-road activities.
TP-Link TL-PB10400 power bank - USB
Power bank
Tablet, mobile phone
4.43 cm x 4.43 cm x 8.88 cm
241 g
Output Connector Type
Total 2: USB - on cable: Micro-USB
5 V
Voltage Provided
5 V
Max Electric Current
2 A
10400 mAh
Cables
Micro-USB cable
Power bank
4.43 cm
4.43 cm
8.88 cm
241 g
5 V
Input Connectors
5 pin Micro-USB Type B
Input Connectors Qty
1
Voltage Provided
5 V
Output connectors
Total 2: 4 pin USB Type A
Detachable Cable Connector Type
Micro-USB Type B
2 A
LED indicator, short circuit protection, overcharging protection, overheat protection, over voltage protection, over-current protection, built-in flashlight, overdischarging protection
10400 mAh
Max Recharge Cycles
500
Carrying pouch
Micro-USB cable
9J37 C2G 2m USB 2.0 A/B Cable - Black In Stock £4.16
