TP LINK TL-PA4020KIT AV500 2-port Powerline Starter Kit
Quicklinx: B0QCWS00 Mfr#: TL-PA4020KIT
TP-LINK's AV500 2-port Powerline Starter Kit, TL-PA4020 KIT, turns your existing powerline into a high speed network with no need for new wires or drilling. No configuration is required, simply plug your adapters into your power sockets and you can establish networking infrastructure in a flash. With a speed of up to 500Mbps, TL-PA4020 KIT transmits HD streaming and even 3D movies to every room, making it a great choice for an easy to build multimedia entertainment network.
Up to 500Mbps for up to 300 Meters
With advanced HomePlug AV technology, TL-PA4020 KIT provides users with stable, high-speed data transfer rates of up to 500Mbps on a line length of up to 300 meters. Together with its built-in AES encryption, the TL-PA4020 KIT is a great choice for a whole home solution to connect all network compatible devices, from computers and game consoles to set-top boxes for IPTV, printers and NAS hard drives.
HD Streaming
Up to 500Mbps powerline speed ensures smooth HD streaming.
Reduce Power Consumption by up to 85%
The TL-PA4020 KIT, a new-generation Powerline Adapters, with its practical design and sophisticated Power-Saving Mode consumes less power when compared with existing Powerline Adapters. When there is no data transmission or reception occurs over a certain period of time, it will automatically switch from its regular "Working" Mode to "Power-Saving" Mode that will reduce its energy consumption by up to 85%*.
*Actual data will vary because of the network conditions and environmental factors.
Plug and Play
You can set up a hassle-free powerline network within minutes with TP-LINK powerline adapters, just plug in and play. Also, the adapters' "Pair" buttons can be utilized for securing or managing multiple powerline adapters in your home powerline network.
*Note: Powerline adapters must be deployed in sets of two or more.
Support QoS for Advanced Multiple-media Optimization
The Quality of Service (QoS) function prioritizes the bandwidth requirements of data traffic. Users can choose which type of traffic they will use -- Internet, Online Game, Audio or Video, Voice over IP, and the QoS functions will guarantee clear, instant reproduction of that application, even when other applications are running on the network at the same time.
  • Up to 500Mbps, 300 meters over the household electric wiring
    With advanced HomePlug AV technology, the TL-PA4020PKIT can provide users with stable high-speed data transmission rates of up to 500Mbps over a household electric circuit for up to 300 meters. This is a great choice for a whole home solution to connect all network compatible devices - from computers and game consoles to set-top boxes for IPTV to printers and NAS hard drives.
  • Extra power socket for additional devices
    With its integrated power socket, the TL-PA4020PKIT provides real convenience for your home network. The integrated power socket allows an additional device or power bar to be connected to the adapter as though it were a normal wall socket. This ensures that even with the TL-PA4020PKIT plugged in, no power outlet goes to waste.
  • Pair button for easy network security
    You can set up a hassle-free powerline network within minutes with TP-LINK's powerline adapters, just plug in and play. Also, the adapters' "Pair" buttons can be utilized for securing or managing multiple powerline adapters in your home powerline network.
  • Mains filter for better performance
    With its integrated mains filter, the TL-PA4020PKIT can optimize powerline communication performance by suppressing noise interference generated by surrounding electronic equipment that can affect network performance. That means that users won't experience a sudden speed drop when a larger power consuming device is plugged into the power socket.
TP-Link TL-PA4020KIT - powerline adapter kit - wall-pluggable
Powerline adapter kit - 2-port switch (integrated)
Packaged Quantity
2 (specifications are for single item)
Enclosure Type
Wall-pluggable
Ethernet, Fast Ethernet, HomePlug AV (HPAV)
Data Transfer Rate
500 Mbps
IEEE 802.3, IEEE 802.3u, HomePlug AV
6.3 cm x 4.7 cm x 4 cm
Apple MacOS, Linux, Microsoft Windows 2000/XP/Vista/7/8/8.1
Packaged Quantity
Enclosure Type
Wall-pluggable
Wired
Data Transfer Rate
500 Mbps
Encryption Algorithm
128-bit AES
IEEE 802.3, IEEE 802.3u, HomePlug AV, Plug and Play, FCC, RoHS
Status Indicators
Power, LAN, link/activity
Line Properties
Line Coding Format
OFDM
LAN: 2 x 10Base-T/100Base-TX - RJ-45 , LAN: 1 x HomePlug AV - power 2-pole
Internal power supply
2.18 Watt
1 x network cable - 2 m
Software Included
Drivers & Utilities
6.3 cm
4.7 cm
4 cm
10 - 90% (non-condensing)
B0QC C2G 2m Cat6 550 MHz Snagless Patch Cable - Blue In Stock £3.67
B0QC C2G 10m Cat6 550 MHz Snagless Patch Cable - Black In Stock £9.82
